Brake rotor issues
You cooked the pads then. I would have hoped the Track Day pads would have held up better from other reviews I have seen. Time to step up to something a little more aggressive.
If I make changes to the front such as new rotors and better pads/fluid the same should be done to the rears also? No getting away with upgrading fronts and leaving rear setup as is? I wonder if that approach might throw off balance under heavy braking...
Supporting Vendor
KNS Blank rotors which are made by DBA.
-Not drilled
-Proven durable
-Fair price
They also do not have the incorrect curved vane design that GM made.
Many users like a bit less friction in the rear of the car. Example would be XP12/XP10 - and the Carbotech pads are generally easy on wheels/paint/rotors.
One piece pads are easier to deal with and should wear more evenly. My padlets in street use tapered from top to bottom.
-Not drilled
-Proven durable
-Fair price
Supporting Vendor
St. Jude Donor '11,'13
I would not run two different pad manufactures front and rear. So, yes I would recommend doing front and rear.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
