Torque wrench
Old 10-05-2018, 05:44 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Torque wrench
Ok time for a new one
The one I've been using for 20years ratchet finally broke
What's everyone using?
I want to take it to the track so.no high $$$ certificated
Old 10-05-2018, 06:11 PM
Mordeth
Mordeth's Avatar
Received 1,678 Likes on 878 Posts
2018 C6 of Year Finalist
St. Jude Donor '10, '17
If you can swing it, grab this one:
Amazon Amazon
It is a split beam, has a flexible head and doesn't need to be turned down after use like standard click style. It's also made in the USA and has excellent range of torque capabilities (40-250 ft-lb).
If not, just go to Harbor Freight or buy a Tekton on Amazon for $35. Lowes has a Kobalt for around $50-$60 that is pretty good also.
BrianCunningham (10-10-2018)
Old 10-05-2018, 07:27 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Kobalt for me, it’s well built and is longer than many which is nice for high torque suspension pieces etc. My favorite so far.
Old 10-06-2018, 07:59 AM
apex26
apex26's Avatar
DON'T buy a Sears, they've gone to crap. After returning three and getting replacements that promptly broke, the fourth is lying apart on my workbench, getting ready to go to the metal recycler. Husky makes one that is modestly priced and so far so good--I bought a huge one at Home Depot, but the one Anthony mentions above sounds great for the normal sized one that gets the most use.
Old 10-06-2018, 08:50 AM
Feffman
Feffman's Avatar
Brian:
I just purchased a CDI torque wrench (http://www.cditorque.com/) from Amazon. CDI is owned by Snap-On and manufactures Sanp-On's torque wrenches with about a 40% price premium for the Snap-On name.
I bought this one:
Amazon Amazon
Hope this helps.
Feff
Old 10-06-2018, 04:08 PM
pjazz
pjazz's Avatar
C6 of Year Winner (performance mods) 2019
Originally Posted by Mordeth
If you can swing it, grab this one: https://www.amazon.com/Precision-Ins.../dp/B002XMSFIM
You took the words out of my mouth. I've had mine over 10 years.
Old 10-06-2018, 11:02 PM
REVHARD
REVHARD's Avatar
second for a Kobalt
Old 10-07-2018, 03:46 PM
c4cruiser
c4cruiser's Avatar
Originally Posted by REVHARD
second for a Kobalt
If the use of the torque wrench is primarily for lug nuts when changing tires, then the Kobalt 1/2" drive torque wrench will work well. Just remember to loosen up the dial to the lowest setting when not in use. The Tekton wrench will work fine too. I have a Craftsman 1/2" drive torque wrench that I have had for about 12 years and it still works. IIRC, most of these brands are accurate to about +/- 4% Not sure I would trust a HF torque wrench for anything other than lug nuts and even then maybe just for street vehicles.
Old 10-07-2018, 06:18 PM
Kevova
Kevova's Avatar
Pawn shops and second hand stores. Craigslist possibly. A professional level tool for 50% or less
i rarely look for substandard tool unless time becomes the deciding factor. Just my opinion.
Old 10-08-2018, 10:44 AM
waddisme
waddisme's Avatar
I bought one of the $100 1/2" Brownlee ones they selling on here a couple of years ago to repl my $13 HF. I am sure it is more accurate, but not that different from my HF. The longer handle does work better for wheels, but makes it almost useless for anywhere else without a lot of space. The beep is cool but switching batteries out before using is cumbersome. For wheels and checking my suspension parts, the HF is good enough for me. If I was doing a motor, maybe not. HTH.
Old 10-08-2018, 03:22 PM
mnmthoele
mnmthoele's Avatar
I pick up a new Harbor Freight one every year or so to take to the track. With the coupon it's $10. I've compared it with a better one I keep in the garage and it's always very close to the same torque. I never have a problem loaning it out to someone that may be new to the track and didn't know about having one.
Old 10-13-2018, 01:02 PM
C6_Racer_X
C6_Racer_X's Avatar
If you're mainly using it for lug nuts, an old fashioned "beam" type torque wrench is the way to go. Amazon has several choices under $20.
Also from Amazon, I recently picked up one of these 1/2 inch drive "digital torque adapters." http://amzn.com/B009GLISI0
It works with any 1/2" drive ratchet or breaker bar (or any other drive tool), and it seems to be quite accurate. It takes a bit of getting used to, but for the price, I really like it.
BrianCunningham (10-14-2018)
Old 10-14-2018, 02:33 AM
froggy47
froggy47's Avatar
For everything except motor work the HF works for me. Testing I have come across stated they all ($10 to $250) are accurate +/- 4%. So I guess if you think about that even the HF for motor although it doesn't seem right?
I wouldn't mind if it were about 6 inch longer.
Old 10-16-2018, 10:43 AM
C6_Racer_X
C6_Racer_X's Avatar
If you're happy with the one you have, have you looked into a repair kit for the ratchet? What do you have now?
Old 10-16-2018, 04:09 PM
Rx7Rob
Rx7Rob's Avatar
I took mine apart when the ratchet mechanism stopped working properly. Some cleaning, fresh grease, and reassembly and its still working about 10 years later.
Old 10-16-2018, 10:28 PM
Metalgearsolid_x
Metalgearsolid_x's Avatar
https://www.eastwood.com/digital-ele...2in-drive.html
Old 10-16-2018, 11:44 PM
pjazz
pjazz's Avatar
So what did you get Brian?
To Torque wrench
Old 10-22-2018, 07:47 PM
BrianCunningham
Big push @ work, still on hold
Old 10-22-2018, 09:44 PM
fleming23
fleming23's Avatar
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Well, while Brian may not have ordered anything, you fools caused me to upgrade to the Precision Instruments Split Beam....
Old 10-22-2018, 11:32 PM
pjazz
pjazz's Avatar
It won't disappoint.
Quick Reply: Torque wrench
