Advice on C2 Alignment Specs for street vs track day
Hey all;
Just picked up a C2, pretty modified with Van Steel suspension, including coil overs, adjust able a arms etc...
Anyone willing to share aggressive street/track day alignment specs?
Thanks!
Thanks!
Alright, I was holding off waiting for somebody who does more street/track setups, but since nobody has replied I'll take a shot. Understand please that my experience is with stock-type suspension (and all the warts that go with it). I'd start with something like this:
Front camber 1.5-2* negative
Front caster approx. 5* or as much as you can get with your setup
Front toe 0
Rear camber 1-1.5* negative (approx. 0.5* less than front)
Rear toe 1/8-1/4" total (I run closer to 1/4" or maybe even a little more, due to the toe steer of the rear suspension. Your setup may allow you to get away with less.)
Vansteel should have an alignment guide posted somewhere I'd think.
Front toe 0
Great, Thanks!
When it comes to geometry, what do you find works best for ride height and what angles ranges should a arms and rear toe links be set at ?
Best
Andy
Best
Andy
With your setup I'd call Vansteel for recommendations.
1Cerberus4u (11-09-2018)
Street Alignment is the easy one. Factory settings gives you best tire life. Great if you drive many miles a year with your corvette. This is not the norm. Most do less than 1500 miles a year, and if you are in this group I would not worry about street vs track alignment and stay on the street aggressive/ track alignment.
Look at this https://tech.corvettecentral.com/201...ignment-specs/ this is a good spec starting point for a street only car.
So lets start with best track alignment. This will take many track days to learn what each track / road course likes.
So here is what to look for.
1. Tire Pressure hot while on the track.
2. wear pattern at all 4 corners.
3. Type of tires used.
The goal is to maximize tread life with maximum grip.
For track days find a solution that allows you to get tire pressure in real time. I use a product from TireMinder https://www.minderresearch.com/
For my local track I use the following.
Caster > 5.4 degrees
Camber -2.8 to -3 degrees.
Front toe ~ 0
Rear toe ~ 1/8"
I started @ - 1.8 camber and for my local track. The outer edge of the tires wear pattern was much higher than I liked.
I also determined toe settings ~ 1/8" for the rear helps with high speed braking. Less Toe more squirrely feeling during braking.
Front Toe settings depends on how you want the car to turn in. Toe out for quicker turn in with less steering. Usually toe in settings makes the car feel like its under steering.
More caster makes the steering return to 0 better for a smoother feel exiting a corner.
There is no perfect alignment, it depends on tires/size/ pressure on track / track temp your desired driving style. So expect to adjust based on taking constant measurements after each track session.
So if you plan on switching street to track and back to street then it is worth investing time on learning DIY Alignment setups.
