Torque tube & clutches
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Saw Wheeler Dealers work on a C5 last week.
https://www.motortrendondemand.com/d...06/0_p35cu91u/
I get removing the Torque tube to change the clutch
I also get pulling the transaxle
But dropping the entire rear cradle with the suspension to change a clutch???
Did they at least change this on the later cars?
Dropping the rear cradle is the easiest way. It's about 10 bolts after you get the calipers and rotors off. Plus you don't even need an alignment if you have a camber kit on the lower control arms.
Yep, rear cradle, transmission/diff have to come out to get the torque tube out. It’s faster and less work to drop everything together versus removing each individual component separately.
I almost always drop the entire driveline. GM made the hydraulic fittings so that you can just drop the rear and slide it back, but getting everything lined back up is hard, and it's still trough to get the clutch out.
Drop everything and you have a great opportunity to inspect the entire driveline
FWIW, my alignment (even with camber kit installed) was off pretty good after dropping the rear cradle to replace diff/trans/clutch. Maybe just bad luck, but we ended up having to shift the cradle a tick to one side once we got it on the alignment rack so I'd recommend at least having the alignment checked after you've had the cradle out.
Location: If you don't weigh in you don't wrestle Road America
dclafleur (11-15-2018)
If you pin the cradle before you drop it out you will put it back in the same spot - I just drill a 3/16" hole right next to the cradle - in line with the rear cradle mount studs - into the frame and tap in a roll pin - do this on both sides and the cradle will be located properly and you won't have to re-align the car.
I'm doing this job now, diff needs a rebuild. Its a bit intimidating i must admit! Figure this is a right of passage if I'm going to track a C5.
