No more leaf springs!!!! C5Z06 want coilovers - Page 3 - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 12-06-2018, 09:52 AM
  #41
village idiot
CF Senior Member
village idiot's Avatar
I dunno. I found the discussion informative.
village idiot is offline
Old 12-06-2018, 10:35 AM
  #42
MatthewMiller
CF Senior Member
MatthewMiller's Avatar
Originally Posted by blackozvet
Matthew Miller - surely you must be on the payroll of the Leaf Spring Manufacturers Association !
We didnt have a debate on the c4 forum - you berated anyone who dared to disagree with you as you wrote volumes of technical opinion.
we get it - you love leaf springs and think they are wonderful - but for the life of me I cant understand why you keep coming onto coil over threads and dominating the conversation with your own pro leaf spring/anti coil over opinions. You are entitled to your opinion, but just have your say and move on, dont come in at post #18 and still be rattling on at post #36 and stifling any real conversation amongst the people who want to discuss (or just read the thread) on fitting coil overs.
I didn't berate anyone either here or in the other thread, and I certainly didn't stifle any discussion. I did provide a number of technical facts (not opinion) to back my statements, because that's how we all learn from one another. You'll notice that you won't find a single ad hominem attack by me in either thread, such as "surely you must be on the payroll of the Leaf Spring Manufacturers Association," or any other form of berating comments.
I'm sorry it was a bad experience for you, but as in this thread I just made one initial post stating a position backed by facts, and then responded to replies. You'll notice that the last post I made here was over a week ago, so the only one dragging this out is you. I'm neither pro or anti any particular form of spring. Since they all do exactly the same thing*, I'm pro using whatever packages best, gives you the rate(s) you need, and costs the least.
What I am very "pro" about is that we should understand what various parts actually can and can't do, and when we make mods to our cars we should understand what we are and aren't getting for our time/money. I'm very "con" about getting sold snake oil, and believing that certain parts have properties that can't be substantiated by empirical evidence (i.e., voodoo/magic). In a forum that was created to help Corvette owners share and obtain useful information about their cars, I think that is very on target with the "mission statement." So far, in two different threads on this topic, you're the only person who's objected to having that discussion. Even the OP for this thread, who ultimately went a different route than I suggested, explicitly stated that this discussion was informative and helpful. Furthermore, I'm well within the guidelines of debate for this forum. I invite you to read and consider those same guidelines, as well as all the Forum Guidelines and Rules.
*Air springs are a little different, and they have their place too. I've left them out for clarity's sake.
MatthewMiller is online now
Old 12-10-2018, 10:40 AM
  #43
kdm123
CF Senior Member
kdm123's Avatar
Great discussion; very informative, especially in relation to leaf springs.
I switched to coil overs on my C5Z. I haven't seen a big improvement in lap times, though I haven't corner weighted the car or done much other tuning. I do miss having leaf springs just for the fact that they are a neat Corvette tradition. If I did it over again, I'd just keep the leaf springs and buy high-quality adjustable shocks.
kdm123 is offline
Old 12-10-2018, 11:12 AM
  #44
[email protected]
Premium Supporting Vendor
Dane@LGmotorsports's Avatar
What coilovers/sway bars are you using?
Dane@LGmotorsports is offline
Old 12-10-2018, 02:34 PM
  #45
TrackAire
CF Senior Member
The correct alignment and corner weighting will make a big difference even on leaf sprung cars.....installing coilovers and not doing a performance alignment and corner weighting can definitely make a car handle worse than stock. Also, when doing the corner weighting I recommend disconnecting the swaybars and only using adjustable end links so the bars are neutral at rest and not pre-weighting the corners.
TrackAire is offline
Old 12-11-2018, 01:30 AM
  #46
kdm123
CF Senior Member
kdm123's Avatar
Agreed. I'm pretty lazy and ignorant about suspension tuning. My new year's resolution is to get the car corner weighted and to get serious about taking tire temps and pressures. I'm running the AFE spec-Corvette coil overs and bars.
kdm123 is offline
Old 12-11-2018, 03:55 AM
  #47
TrackAire
CF Senior Member
Toughest part of doing a correct alignment and corner weighting is finding a shop that knows what they're doing. If in NorCal, Abel is a great option. For SoCal, I suggest asking some of the Spec Corvette drivers who they use down there.
Alignment is only as good as the condition of the A-arm bushings, ball joints, hub bearings, tie rods, etc. Even though you have coilovers, don't waste your money on an alignment until you can verify the other components are in good working order. When everything is working correctly, you get faster because you have trust and repeatable predictability in how the car is going to respond at the limit.
Let us know how it goes!
Old 12-11-2018, 02:28 PM
  #48
AND0
CF Senior Member
Shout out for Custom Alignment in Mt View for a Nor Cal shop that knows what its doing.
AND0 is offline
Old 12-11-2018, 02:43 PM
  #49
Olitho
CF Senior Member
Olitho's Avatar
In Southern California most of us use West End Alignment in Gardena or Lang Development in Lake Forest.
Both do corner balance and race alignments. They can probably install the hardware from scratch I bet.
Oli
Olitho is offline
The Following User Says Thank You to Olitho For This Useful Post:
SVT_Z06 (12-20-2018)
Old 12-11-2018, 02:50 PM
  #50
Sub8
CF Senior Member
This.
Get car aligned. Realised I wasn't happy with the rake. Adjust. Align.
Realise I had some play in the rear tie rod ball joints. Fix. Align. Again. Lol. My buddy very ha$$y to see me. Again!
Sub8 is offline
Old 12-20-2018, 10:45 AM
  #51
SVT_Z06
CF Senior Member
Just ordered Aldans. Can't wait!
Thanks again everyone! My thread is super informative. Glad I made it! Haha!
So far i have new front and rear end links, new front and rear sway poly bushings, new front and rear tie rods.
SVT_Z06 is offline
Old 12-31-2018, 01:17 PM
  #52
SVT_Z06
CF Senior Member
Just finished installing my Aldans. Test driven over a bunch of bumpy roads and the car doesn't get upset like it used to.
I still need to perform some adjustments, alignment and corner balance, but so far its looking very promising.
Install would have been faster if I didn't have to grind the front sway bar down a bit at both end link attachment points. A bit disappointed with that.
SVT_Z06 is offline
Old 01-02-2019, 07:36 PM
  #53
RSbeast
CF Senior Member
Curious on updates.
RSbeast is offline
Old 01-11-2019, 09:38 AM
  #54
SVT_Z06
CF Senior Member
Default Just a few pics....its low....but compliant!
SVT_Z06 is offline
Old 01-11-2019, 09:42 AM
  #55
SVT_Z06
CF Senior Member
Still need to get it aligned and one coil over is hard to adjust. I'm trying to get that worked out with Aldan.
Initial improvements without an alignment are night and day. It was aligned just prior the install.
There appears to be a break in period, which I'm still in. I'm hopeful it may get better with a few hundred or so miles.
SVT_Z06 is offline
Old 01-11-2019, 03:57 PM
  #56
MatsA
CF Member
Yes i had to grind my Steinjager swaybar that was in the suspension package from TPS also when installing the Aldans otherwise satisfied with the Aldans.
MatsA is offline
Old 01-11-2019, 05:33 PM
  #57
fleming23
CF Senior Member
fleming23's Avatar
I like your cheat sheet notes on the frame and control arms.
fleming23 is offline
Old 01-12-2019, 07:36 PM
  #58
BrunoTheMellow
CF Senior Member
BrunoTheMellow's Avatar
That would rub in high G would it not?
BrunoTheMellow is offline
Old 01-15-2019, 08:53 PM
  #59
SVT_Z06
CF Senior Member
So.....one of the adjusters kept getting stuck, so I got my replacement....but I have to send it back because the thrust bearing wasn't installed.
So....I decided to do a quick rebound comparison. Old vs. New. On the hardest setting on the old one, rebound seemed way to fast. It's faster than my stock shocks! That's not right. So I tested the new one, rebound on the hardest setting and it was slow....like it should be.
I'm going to test the other rear shock as well. But so far, the month old rears don't have the rebound they are supposed to.
That being said, Aldan was very nice and understanding and will be sending out new ones today. I just hope these have the rebound they are supposed to.
SVT_Z06 is offline
Old 01-15-2019, 09:02 PM
  #60
SVT_Z06
CF Senior Member
Default Video of rebound for rears
https://youtu.be/GQh9_-t7c5w
SVT_Z06 is offline
Quick Reply: No more leaf springs!!!! C5Z06 want coilovers
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
