Delrin Bushing maintenance?
Looking at buying a Delrin bushing set for my C5 from Borg Motorsports. I spoke with Lane and he said I would be fine running the Standard set with my set up. He said the standard "might" need maintenance while the Premium set up with the AF Delrin would not. 350 is a big price difference.
I really dont want to take the Control arms off to lube up the bushings every couple years. I have read on here that guys have gone 20k and counting on standard delrin with no issues. My car is 90 percent street car and does see time at the drag strip.
Any guidance is much appreciated.
AF is just tougher longer lasting slower wearing. If you keep the car for 5+ years get the good stuff. Less than 5 yrs let it be the next guy's problem. If you are all race get the good stuff.
Just did the Borg offset bushings, https://www.borgmotorsports.com/coll...100af-bushings with the AMT camber kit, https://amtmotorsport.com/products/c...ble-camber-kit.
You will not regret it. You are connected, part of the car, inputs are precise, no squeaks and the cars ride is one that you could take long distances. My car is setup with coilovers, stock mono leaf may have a firmer ride.
Supporting Vendor
Borg Motorsports (11-25-2018)
Supporting Vendor
I won't call out specific brands, but some brands do hand-fit each order of bushings and others (include us) don't. Our kit can be customer installed. I've done a ton of research and testing on the variability of the stock control arms and feel we have a solid solution that addresses the variances without the need for custom machined parts.
Supporting Vendor
In terms of caster/camber, it will depend on the kit you order. The standard and premium kits allow all the factory adjustment. There is no binding with stock components. If you have an aftermarket camber kit, aftermarket control arm, etc. then I can't guarantee you'll have a combination that functions perfectly. As long as you are staying within the factory adjustment range, you should be fine. People think Delrin will bind because they compare it to aluminum or sphericals. In reality, it's closer to polyurethane than it is to aluminum. As long as you account for the needed movement in the tolerances of each part and the design as a whole, they function perfectly fine in the suspension arms. Where Delrin IS too stiff for movement is in the shock mount bushings. Those bushings have a much higher degree of misalignment and multi-axis movement that requires either a very flexible material (i.e. rubber) or a change in the type of bushing to allow multi-axis rotation (i.e. spherical bearings).
Getting back to your caster/camber question, if you step up to the offset kit, you can get the same range of adjustment as stock, but that range is offset. It will depend on your specific car, but generally, you can get an additional 2 to 2.5 degrees of negative camber at the same caster level. For example, when our shop car was stock, the front alignment maxed out at about -2.4 camber and the highest matched caster I could get was 6.2 degrees. With the offset bushings, I can get up to -4.9 degrees of camber at the same caster and still have a little wiggle room if needed. In practice, I run less than that in camber and can get the caster I want in the car. The idea of the offset kit is not to max out your settings, but to give you the ability to have your settings at a not maxed out position when at your desired values. This gives you the ability to try things and tune to your needs without being restricted to the factory limits.
Keep in mind though that the benefits of the offset kit on the aggressive side (aka the track-oriented side) are the opposite on the conservative, street-driven side. Ex. If your stock camber range was 1.0 to -2.5, your new range with the offset kits will be something like -1.5 to -5.0. For a track or performance oriented car that has no street driven considerations, this is fine. If you switch between a track and street alignment frequently though, you would likely be better off with the non-offset kits.
1. Infusing delrin with PTFE fibers makes it weaker than the same grade delrin without it.
2. The purpose of PTFE in delrin is to make it slippery. A properly designed bushing kit will use metal sleeves inside the bushing for the control arm bolts to pass through. The result is that the bushing never rotates around anything so being slippery isn't a requirement. It simply takes up the space between the sleeve and the control arm.
The only exception on our cars is the front upper bushings where the bushing material rotates around the “dogbone” pin that’s secured with snap rings. Even in this scenario, regular delrin works perfectly fine. I cut my own bushings over 3 years ago using standard (black) delrin and I didn’t use any sleeves. The control arm bolts contact the delrin directly and it works great.
The metal sleeve in the middle of the bushing is usually pinched between and captured by the mounting tabs so it does not move. In this manner, like a stock rubber bushing, the center sleeve does not move when the arm does.
So the delrin (or poly) either stays with the control arm and rotates around the center sleeve or it stays with the center sleeve and the control arm rotates around it. Or it moves around both.
If you have no center sleeve then the bushing interacts with the bolt and either slides around the bolt or it stays with the bolt and the control arm rotates around the bushing.
Obviously regular delrin works fine, but as to whether or not there is a noticeable difference with the ptfe delrin in performance or longevity, I have no idea.
Although I would think that it must add an appreciable amount of friction reduction as to justify its development and production. Do we need this improvement in our cars? Only back-to-back testing would give us any idea.
What about the maintenance aspect? That’s why I bought the ptfe, I didn’t want to take the car about to lubricate the the bushing every spring. Or even every other spring. That’s why I purchased them. From what I’ve read l, with ptfe, I wouldn’t have to maintain the bushing which was my goal because they self lubricate.
