Any recommendations for turning plates
Looking to pick up a set of economical turning plates. Does anyone have any they'd recommend or ones to avoid.
Also you can stack the tiles to level out the floor. Most floors can use a little leveling to get most accurate alignment. Buy a 6' level from warehouse store to check.
I made my own using ball bearing turn tables from McMaster Carr and some steel plates. PM me if you want the info.
I should mention that it does require a bit of welding to weld the plates to the turn tables. I would post pictures but I haven't figured out how to do that on the new forum format.
Received 8,928 Likes
Bill
Not any different than it used to be. Click the picture icon and you get 3 choices from which to select pictures. Once you select the ones you want you just upload them by clicking on open and the picture gets uploaded to the forum. Then all you have to do is choose insert and submit. Photobucket screwed things over because of their fee structure so it isn't easy to find a site that will let you link to pictures on the site for free.
Bill
Bill
I think it's an issue with my browser version.
I use a few sheets of thin wooden paneling, have different shapes and sizes. Just don’t jack up a leaf spring car during alignment or all of your measurements go out the window
You can’t jack up ANY car during without changing the alignment. You must always roll the car enough to allow the suspension to settle before re-measuring.
I suppose jacking a live axle car in the middle of that axle (which is usually not recommended) might be the best chance of jacking and lowering without changing something but i would still roll the car back and forth.
This is why alignment racks racks have you drive on to the rails then lift the rails.
Pro Mechanic
Early style alignment machines required each wheel to be lifted off the deck for calibration, and most professional alignment rack have slip plates in the rear, allowing independent rear axle cars to better return to ride height. Professional front turn plates are 'floating' (not a caged-bearing setup that only pivots around a center) and are free to slip in and out as well.
But some cars have so much friction in the suspension that they won't return to that level without actually driving them.
Leaf spring Corvettes
Porsche 928s
Cars with new Bilsteins...
Porsche 928s
I align and scale my car on a twin post lift. I find the bucket of water, aquarium tubing, and ruler to be the most effective and accurate way to level your scale pad locations. I used to use 1/4" heavy steel greased plates. Now I use grease light 1/8" flooring tile. I use the flooring tile to set my pad heights. I have an additional 2 tiles that are grease per pad location. I have delrin suspension in my C5Z so I have very little suspension stichion. I have proven to myself that I can get reproducible results on the scales whether I am using thick unbending steel slip plates or then 1/8" flooring tiles. I don't use the heavy steel plates anymore.
Robert Thomas (12-09-2018)
Rolling a leaf corvette won’t settle the suspension, you have to drive it. You can settle a coil car on the rack by bouncing/rolling.
I am only making it clear, from experience, that there is a huge distinction. Ideally you would lift neither, but I can put a pole jack under a corner for minor tweaks on a coilover car and have it resettled in a few seconds. Absolutely can’t with leafs
Thanks for all the input. I understand what is being said about using grease plates(cheap alternative) I was hoping to find a set that
has degrees indicated on them.
I'm in the middle of working over a 07 A6 Z51 track car build on a budget.
All your inputs are appreciated.
