Can a Vette be jacked up from the side like a NASCAR?
One of the best modifications I added to my previous track Mustang was jacking rails like these:
http://store.kennybrown.com/product/...tang-and-cobra
This allows you to lift the side of the car from one central jacking point (like NASCAR) which I found very convenient and also allows for easy placement of two jack stands. It worked great when needing to get the car off the ground in the paddock.
Is there anyway that a C5 Corvette can be lifted from a single jack point under the door area? I've seen the aluminum rub strip that Elite Engineering sells but I'm not sure you can jack up the car from under the door using that. Any ideas or experience doing this with the C5 chassis?
There are two jacking points at the factory tie-down location on each side of the frame. Jacking at either of these points will lift the entire side of the car, though I tend to use two jacks, one at each location.
I do mine a lot from there. If you look under there, there is a metal brace that runs across the body about midway. It has a nice big round flat area for jack to go without having to use jacking pucks. I go from there when switching out pads and rotors for track days, so it doesn't have to be lifted far. HTH.
I want to be able to lift the entire car from the side with a single floor jack and once that side is in the air I have to perfect spots for the jackstands....then I repeat on the other side.
I have jacked the C5 at the point Waddisme indicates at least a hundred times. It works perfect. Jack up drivers side, put stands under the front and rear jack points, let jack down onto the stands. Go to passenger side and repeat. IMO there is no easier car to get up on 4 jack stands than a Vette due to its perimeter frame. Way, way easier than a unibody.
my Z06 is so stiff, i can jack it from the front or rear jack point with pucks, and it lifts both front and rear tires off that side. its super handy!
my old 2000 SS wouldnt do that, you would see the unibody twist and hear the t-tops pop doing that! and would leave the further wheel on the ground
C5, C6 and C7 can be carefully jacked up with a single floor jack placed on the frame between to the 2 jack points with the tie down slots. On C5 & C6 there is a strap running across the width of the car at that point. It is not a structural member, you can put the jack on that but it ends at a connector on the frame and you use that. It’s roughly in line with the back of the door and seat. There is a similar point on the C7 but you don’t see the cross strap (if my early morning recollection is correct). I have been doing this since 02 this way with a lightweight Harbor Freight jack that even works with the C7 side skirts. Once up it’s a snap to put in 2 jack stands, repeat on other side and go to work.
TrackAire (12-16-2018)
The other issue that I don't feel comfortable with is when jacking from either the front or rear jacking point with the other side of the car already on jackstands, I worry about the car being pushed off the jackstands due to the side loads from lifting from either the front or rear jacking point 12" high or so. Let me know if I'm understanding your explanation correctly.
Check out this thread about properly lifting a C5, especially post #82.
https://www.corvetteforum.com/forums...ng-pads-5.html
Maybe I do not understand this post. You are concerned with pushing the jack stands over from lifting the car from the rear when the front is on jack stands but you are not concerned from lifting the car from the side when the other side is on jack stands.
But as others have stated, you can pick up the car from the middle where the center of gravity is probably more favorable and also not "torquing" the chassis forward or backwards on a suspect surface. I just didn't think that center jacking point was strong enough structurally but as others have proven it is. So for me, problem solved and thanks to the others who confirmed this.
Received 8,927 Likes
I don't have any pictures of my C5 up on the jack but I did take some of my C7 which is pretty much the same from this standpoint.
I have another picture showing the right front off the floor as well but it doesn't show it clearly. There is plenty of clearance around the front shipping slot on the C5/C6/C7 so you can get by with out a puck (even the GM C5 Factory Service Manuals only indicate they are required at the rear shipping slots when lifting the car with a 4 point lift). When I first took delivery of my 97 in May 97 I used to use a 6 inch long piece of 2x4 between the jack and the frame, then I went to the metal pucks. I have also used good old hockey pucks which are just as good and at about $6/ea a hell of a lot cheaper than the metal ones but not as cheap as a piece of scrap wood.
As for jacking on the ground the biggest problem I found was the jack pushing down into the dirt Vs lifting the car.
Bill
