[BUILD] My Ultimate C7 Track Car - The C7 GS.R
#221
#222
Premium Supporting Vendor
It's not on the website yet because I want to get final pictures on the race car we are building. It is an outer roof skin that can either be bonded to the OEM frame for street applications, or can be bolted to the cage to allow higher halo placement (bonding of brackets required).
The following 2 users liked this post by Katech_Zach:
bbbvettes.com (06-16-2019),
RapidC84B (05-13-2019)
Poor-sha (02-07-2024)
#224
Supporting Vendor
Received 2,314 Likes
I decided to throw the car on the scales one more time before I drop it off for the cage. Just to recap, this is the config:
- 2019 Corvette GS M7 1LT w/ PDR
- Full fuel tank
- 18" Forgeline wheels and Pirelli DH scrubs.
- Akrapovic axle-back exhaust
- Added ZR1 rear wing bracing and spoiler but not rear wing (yet)
- Removed parking brake assembly including actuator and cables.
- Removed washer fluid and pump
- Removed 1 factor GT seat, still had one in it.
- Removed all carpet and plastic trim except:
- Full dash
- Center console
- door panels and glass
This isn't the car on hubstands on the scales and you're being sneaky I hope...lol. I recall you bought some when I did...haha.
#225
Track Rat
Supporting Vendor
I've been dragging myself. I bought them right before I moved from Ga to LV...I have them built, but haven't used them. About to do a setup shortly so, I'll be doin my first run with them.
#230
Track Rat
That was just for general illumination although it doesn't add a lot of light it does help. It was a cheap item I bought on Amazon.
#231
Track Rat
Alright, I just picked the car up from Piper Motorsports and they did a phenomenal job on the cage. I mentioned previously how we had to buy a roof skin from Katech and then bond brackets to it in order to get the room for the bars that run along the top next to your head. I just finished weighing the car and overall the car gained 80 lbs with the cage bringing the new weight on 18" Forgeline wheels, Pirelli slicks, and a full tank of fuel to 3288 lbs. We'll see how much of that we can drop by removing the A/C, lightened clutch and flywheel, and headers without cats. We might still get to 3200 lbs.
Next step will be to mount up the ZR1 wing, stage 3 front splitter, and ACS composites side skirts.
#232
Nice work Sean!
That thing is going to be wicked on the track!
#234
Track Rat
Here's the Katech exposed carbon fiber roof skin.
A good shot of how far the door bars stick out. This really helps get in and out of the car because you can sit on them.
Here you can see where they made up brackets to hold the mode dial that was in the center console as well as the SD card reader for the PDR system.
They relocated the door release from the trunk and made this red loop for emergency workers that approach the car.
Here's a shot of the door bar on the passenger side. I decided to leave the glove box out to give the passenger a little more leg room. Due to the rollover hoop the passenger seat is moved quite a bit forward of the driver seat.
A couple of shots of the cage and the roof brackets.
The following 8 users liked this post by Poor-sha:
daleong (05-31-2019),
dcooper23 (09-09-2020),
edster75 (06-17-2019),
grandsport2017 (06-03-2019),
and 3 others liked this post.
#235
Track Rat
Finally, here are a few shots I took before they finished up. It shows the top of the cage without the roof.
The following 17 users liked this post by Poor-sha:
383 (07-11-2019),
64drvr (05-31-2019),
Basil2000 (06-02-2019),
Darion (06-03-2019),
and 12 others liked this post.
Poor-sha (05-30-2019)
Poor-sha (05-31-2019)
