[BUILD] My Ultimate C7 Track Car - The C7 GS.R
Old 03-08-2019, 05:30 PM
  #121
STANG KILLA SS
STANG KILLA SS's Avatar
man i LOVE/miss build threads.
cant wait for more! and pics. dont for get pics along the way. slows you down i know.
Poor-sha (03-08-2019)
Old 03-08-2019, 09:22 PM
  #122
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
Here are some other pics I took along the way. I had a bit of a setback after I realized the brake line I replaced was still leaking so I took it to Piper Motorsports and they've got it all fixed up. I'm heading to Spring Mountain tomorrow for the ZR1 owner's class. Thursday morning I plan on picking the car up from Piper, taking it to DSC to check the alignment, and then a quick 500 mile oil change and off to Summit Point next weekend.
Old 03-08-2019, 09:42 PM
  #123
Innovate
Innovate's Avatar
Makes me want a C7 GS instead of a C7Z. Except in my old age I want an auto.
I love the mods done! Hopefully the Katech 427 works for you.
Old 03-08-2019, 09:47 PM
  #124
c5racr1
c5racr1's Avatar
Get a c7 gs auto...
Old 03-09-2019, 12:30 AM
  #125
RapidC84B
RapidC84B's Avatar
Received 13,153 Likes on 5,984 Posts
Was the hose leaking caliper side or hard line side? Bad flare from the factory or over tightened factory? Asking because I haven't done hoses on my C7 yet and have heard stories of way over tightened fittings crushing the bubble flare so it only seals the first time.
Old 03-09-2019, 05:51 AM
  #126
Poor-sha
Track Rat
Poor-sha's Avatar
The hard line was leaking. I cross threaded the RR hard line so I just replaced it. Then it was leaking where the new and old hard lines connect. All self inflicted.
Old 03-09-2019, 09:49 AM
  #127
badhabit_wb
badhabit_wb's Avatar
Sean when I pulled mine apart the hard line threads were crossed on my left front wheel. I know I didn't do it because I never could start the damn thing. I pulled the hard line off and bought a die and chased the threads and it worked fine. I think when they screw the steel line into the brass fittings crossed that they can get a good seal, once, and not totally ruin the threads. When I put the stainless lines on that's when I ran into trouble. You probably didn't cross thread it. It probably was done at the factory.
Old 03-09-2019, 01:29 PM
  #128
KnightDriveTV
Supporting Vendor
KnightDriveTV's Avatar
Received 2,316 Likes on 990 Posts
Out my way in Vegas...werrrd....cool day out here today, those ZR1's gotta be haulin *****.
Poor-sha (03-09-2019)
Old 03-09-2019, 08:16 PM
  #129
Poor-sha
Track Rat
Poor-sha's Avatar
I counted and this was the 6th time I've replaced the soft lines on a C7 and it was the first time I've had a problem. This one has been a real bugger though.
The forecast just keeps improving. The latest is low 60s and sun for Sunday/Monday. Hopefully it ends better than the last time I was behind the wheel of a ZR1
Old 03-09-2019, 08:25 PM
  #130
badhabit_wb
You'll have a blast. Have fun!
Old 03-09-2019, 09:51 PM
  #131
Stephen02Z06
Stephen02Z06's Avatar
wow...what a build! Hope to see this beast at VIR soon. I have a lowly black ZL1 now and look forward to seeing this GS in person.
Poor-sha (03-10-2019)
Old 03-09-2019, 10:18 PM
  #132
BradT
BradT's Avatar
Originally Posted by quick04Z06
Understood, but my question is if I do not want to run 18 inch slicks, what DOT legal track tires work on 18 inch wheels for our cars?
Thanks so much.
Here is what I have on my track set of 18's.
Toyo R888R sizes:
Front 315/30-18 on 18x11
Rear 335/30-18 on 18x12
Fronts rub slightly at full lock. Otherwise no issues.
Old 03-09-2019, 11:38 PM
  #133
96GS#007
96GS#007's Avatar
Received 1,739 Likes on 1,047 Posts
Is the heat wrap on the tie rod ends and ball joints your recipe (and if so what is it? ) or what brand is that? Looks more robust than the usual stuff.
Old 03-10-2019, 06:54 AM
  #134
Lasco001
Lasco001's Avatar
3 questions
-What do you do with cooling from the engine, you need deep water temp
-I see you stay with the original chassis, no coilover
-Sway bars, remains original? I've been looking for a better product for the racetrack for a long timeHave fun with your two vehicles
Here is a picture of the season opening in 2019 with my little one
Old 03-10-2019, 11:26 AM
  #135
Poor-sha
Track Rat
Poor-sha's Avatar
I plan to be there for the Audi event April 9/10 but I won't have the motor work done yet.
That's a product called heat sleeve that I first heard about on this forum back when I had my 2008 C6Z. I then put some of the aluminum foil tape around it to create a heat reflective surface. Here's a thread on it and I ended up buying the 1.5 ID from Pegasus Racing.
https://www.corvetteforum.com/forums...iresleeve.html
Originally Posted by Lasco001
3 questions
Thanks, I've been following your posts for many years.
Cooling - the GS already has the secondary radiator in it like the Z06 and I'll be removing the air conditioner so that won't be blocking flow to the main radiator. There also isn't an intercooler blocking flow to the mian radiator like the Z06 so I think this should be more than adequate for ~700HP NA motor. We're also going to be adding the Katech external oil cooler when they do the work. My biggest concern is transmission temps as those were an issue on both the Z06 and ZR1. I'm hoping the RPM polishing and treatment will help with that but I might be looking for other options.
Suspension - I really like the DSC Sport controller and dynamic damping. You can't beat a suspension that can respond in real time to the car inputs and with the Tractive DDA shocks we have a real race quality shock package that you can still further tune the shim stacks and such. The FE6 springs are definitely too soft so I went with the FE7 springs. I'm hoping these aren't too stiff with the lighter GS but we will see. The Tractive shocks are threaded for spring perches but there are fitment issues on the C7. If we find out the spring rates are really off then perhaps we will look in to a way to make the coilover springs fit.
Sway bars - Yes I'm staying with the FE6/FE7 bars and FE7 bushings. They were designed to work with the FE7 package and I haven't found a reason to change them so long as the springs are right. Right now I think I can tune the car the way I like it with the shock controller. It seems like the Stingray needs them because of soft springs, what are you finding?
The following 2 users liked this post by Poor-sha:
96GS#007 (03-10-2019), Bigblue77 (12-31-2019)
Old 03-10-2019, 11:30 AM
  #136
vettenutchas
vettenutchas's Avatar
Also interested in what everyone is using for wrap to insulate ball joints and tie rod ends, any help greatly appreciated!
Old 03-10-2019, 01:38 PM
  #137
Lasco001
Lasco001's Avatar
@Poor Sha
Thank you Dirt for your answers
Cooling: I'll give you the TIP, your Wassertemp should be a maximum of 85-90 during a race or trackday, you'll see, your engine lives long and you always have optimal performance.
I have on my green Z06 and on my new white the Bilstein MDS 2 GT3 Coilover with Race spring rate
The optimalway bars I have not found yet
I will also test the FE7 once
To [BUILD] My Ultimate C7 Track Car - The C7 GS.R
Old 03-11-2019, 10:59 AM
  #138
RapidC84B
RapidC84B's Avatar
On my C5 I used DEI Cool tape.
On my C7 there are factory heat shields in place, but OP may have removed his for his specific brake setup.
Old 03-11-2019, 08:21 PM
  #139
Mad Dog 24
Mad Dog 24's Avatar
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
Would you mind telling us\me what the silver circles are behind the grill in your white Vette? I have something similar for oil cooling.
3 questions
Old 03-12-2019, 10:51 AM
  #140
thebishman
thebishman's Avatar
^ Brake ducting I'd wager
Quick Reply: [BUILD] My Ultimate C7 Track Car - The C7 GS.R
