Anyone Make C7 Headlight Blanks?
Track Rat
Does anyone make headlight blanks for the C7? I'm looking for something I can use to fill the hole if I remove the headlight assemblies to save weight. Ideally it would attach just like the stock pieces so I can swap the lights back in if I need them.
Do you have the lens covers? I can make some CF covers, but need yours to make mold. I'm not sure how to best attachment, at high speeds they have to really be on there solid. You'd have to install some brackets/braces in the hole that sit behind the blank and allow the blanks to attach to the tabs/brackets
Track Rat
Sean - Contact AJ Hartman of AJ Hartman aero. If you send he your lights he can make bolt-in fillers that would screw into the OEM mounts I'm sure. I was thinking of the same thing.
https://ajhartmanaero.com/
Sean,
I am currently building a set of carbon fiber headlight block-offs for a Viper. The factory units weigh 11 lbs. each. If you are interested, I will post photos of the process when I get a little further along with the project. I am pulling the molds right now, but the hard part will be the rear braces to the factory pick-up points that will be strong enough without adding too much weight.
Pappy
Pappy
Poor-sha (01-30-2019)
The following 2 users liked this post by mfain:
BrianCunningham (02-22-2019),
RapidC84B (01-30-2019)
Well this building headlight blanks turns out to be a little more complex than I expected. Building the basic blanks wasn't too big a deal - pull molds then pull the blank out of the mold, and finish. However, the car I am working on, and I suspect the C7, doesn't have a very convenient way to attach the blanks to the car. I had to build carbon fiber braces that run back to the headlight mounting posts, but since the headlights were basically unsupported where they meet the front valance it required additional tabs for support. I was able to attach these tabs to the hood with 3M double-sided tape, which appears to work well. I was still able to keep the weight to under 1 pound - a lot better than the 11 pound headlight assemblies. Here are a couple of construction shots.
Pappy
Pappy
Track Rat
Thanks for the update! Still interested in a C7 solution of you come up with one.
Location: If you don't weigh in you don't wrestle Road America
Five star race bodies made them for the C6 - they show all of the windows for a C7 but no headlight covers yet. Maybe give them a call and see if it's something they are planning on.
http://www.fivestarbodies.com/store/...parent=82&pg=1
Poor-sha (02-12-2019)
Track Rat
Originally Posted by 3X2
How about getting a pair of used/non working ones and gutting them?
RapidC84B (02-19-2019)
Track Rat
A buddy backed in to his C7 and cracked one of the headlight lenses. So I have a passenger side. Now I just need a divers side.
