NCCC autox scrutineering intensity
So I disliked my seat in the C4 from the moment I got it. Its plasticky, feels cheap, and flops about. In addition to that, about four panels were ripped up, and the rest of the seat wasn't far behind. Recovering it was going to be expensive. In addition, the power base is pretty much done with, some of it is nonop, not that I care, because I dislike all power seats and don't like them in any of my cars.
I ordered a Corbeau A4 the other day, which is legal in both SCCA G1 and NCCC STU. Where I'm running into issues is the base. SCCA doesn't care beyond safe, NCCC says stock sliders. NCCC also says if a part is discontinued (all seat bases are), a similar aftermarket nonperformance part is allowed. Is anyone likely to care about using the Corbeau slider base with this seat? Seems safer, easier, and no lighter than trying to rig up junkyard sliders to work with the seat. I'm doing my best to follow both the letter and spirit of the rules.
Are you talking about NCCC autocross classes, in the ISF/G class you can use an aftermarket seat that will fold over (not a rigid racing seat). The rule states:
Stock or STOCK-TYPE, back breakable, upholstered seats mounted securely & safely on stock seat mounting tracks
So the sliders would have to be on the stock mount tracks but as long as it slides front to back I doubt anyone will notice, being securely mounted in the stock bolts from the floor is the real option I would look at..
Yeah, Autox 1F/G. The A4 is a reclining stock type fully upholstered seat. I don't think I have any issues there.
My options with a deadish power rack is either to repair/replace (couple hundred bucks, and my helmet is right up against the roof with that setup anyhow) and modify that to fit the new seat (don't really want to trust my metalworking on a critical safety component), find some manual stock rails on ebay/junkyard (~$90) and hand modify them to fit the new seat (same as power), or just buy the Corbeau mount ($110) which fits both the seat and the stock mounting holes as ordered and slides back and forth like stock. As the factory parts are discontinued and not available, the exact phrase I am trying to use for this is:
"Factory parts superseded WITHIN a Year Group allowed if supported by a factory Recall or Service Bulletin. Factory parts discontinued without a superceded replacement available may be replaced with a similar nonperformance aftermarket part. (01/12)"
If it were SCCA with these rules, I wouldn't give it a second thought, but as it is a car specific group, I'm just wondering if such stuff gets looked at more closely because they know the cars better.
Received 1,753 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
If your helmet is up against the roof now, good luck getting an aftermarket seat AND rails/sliders under there. I didnt have any room to spare in my C4 with a stock seat. I have my FX1 mounted with the bottom touching the floor and my helmet almost rubs still.
On the stock sliders you will have enough room, if you go with the power seat you will sacrifice some height, however you can adjust the seat angle to acquire more area. In Detroit if you go to one of the local Detroit council events you will be in the TSSP class but at a NCCC (Corvette only) event you will run 1SF/G. .However you will be competing against Bob Hall in that class who has every NCCC option available done to his 96 LT4
Received 1,400 Likes
Stock sliders on A4 should be enough room, and I don't see why it wouldnt be accepted since its not very different from the stock setup. Its just a pain in the *** to get all 4 nuts tightened to the floor.
Doing the conversion didn't really get me any more headroom however. The A4 seat is not raked. Its flat bottomed, while the stock seat is raked backwards so you slide back in the seat, but the distance to the floorboard is not really any different at the back of the seat. Its also less comfortable for me and I added spacers to the front bolts to make the seat have a rearwards rake.
OK, thanks for the replies, they're enough I think I'm just going to do the Corbeau base. Still got enough to do on the car before April without adding a fab project too!
Good, I need some competition, I'd hate to just walk in and wipe the floor with everyone :P
(no, I'm not actually that cocky, I don't actually plan on being fast enough anyone would even want to scrutineer me)
At least, not this car, which has passed through a half dozen owners, has no documentation on anything that has been done, being someone who doesn't know what is and is not factory stock on said things (for all I know about Corvettes, this thing could have a hot cam, doubt it, but I wouldn't have the frame of reference to know). Also, I'd probably compete in SCCA, just for the considerable amount of extra competition and which the rules are a bit easier to follow not being car model specific.
For set up and alignment you might also consider trying to get with Danny Kellermeyer (DJRace) if you want the best set up available for the C4-5-6-7. If you go W2W at Waterford Hills, just try to stay out of his class (LOL)
That comes when I have a bigger garage and bank account, though
It is not about being caged it is about alignment, when Danny Popp was starting to expand his alignment knowledge he called DJRace. I have Hub stands, elevated alignment/corner weighing system, etc and still talk to Danny occasionally about alignment considerations and I autocross/track the car as well as drive on the street.
