C7 Z51 TT2/ST2 build thread
Old 04-19-2019, 11:10 AM
  #61
BrunoTheMellow
CF Senior Member
BrunoTheMellow's Avatar
Originally Posted by Tool Hoarder View Post
The only issue I see is the steering override. I would guess if you have it set to "link to drive mode" before you take it out it should stay linked to drive mode, then you're drive mode selector would still work, but I have no idea. The other thing would be exhaust, but once you've ditched the valves then it doesn't matter.
What did you do about your valves? Did your car have the AFM valves (I have the sims for those). Did you just leave the NPP wires unplugged? Any CEL for that? My new exhaust has places to mount the NPP valves, but I don't see the point if they don't do anything and leaving them unplugged has no ill effects. (I know unplugging the AFM valves w/o sims does cause a CEL).
You can tune out the afm cel. Don't need a Sim. Npp does not give cel , otherwise everyone with the fuse pulled would get one.
BrunoTheMellow is offline
Tool Hoarder (04-19-2019)
Old 04-19-2019, 11:18 AM
  #62
Tool Hoarder
CF Senior Member
Tool Hoarder's Avatar
Received 1,485 Likes on 844 Posts
I got a set of EdgyVette sims last year and scooped them up. At the time I still had a year of powertrain warranty I didn't want to give up with a tune. I'll use the sims and just leave the NPP ones unplugged and tape up the ends.
Tool Hoarder is online now
Old 04-23-2019, 02:33 PM
  #63
lobsterroboto
CF Senior Member
Support Corvetteforum!
lobsterroboto's Avatar
C7 of Year Finalist (track prepared) 2019
well... signed up for NASA @ COTA for May 4th/5th
This will be the first time with the car setup to the point I cant make any excuses.
lobsterroboto is online now
Old 04-23-2019, 03:17 PM
  #64
mfain
CF Senior Member
mfain's Avatar
Good luck! Looking forward to the feedback.
Pappy
mfain is offline
Old 05-06-2019, 08:56 AM
  #65
lobsterroboto
CF Senior Member
weekend was excellent
I started out with some Hooser R7 scrubs from a friend who ran them last year at Nat's who said they had "5 heat cycles on them" they proved to be really sketchy and I couldn't get any power down. was getting 2:30's which just.. no...
Put on some fresh tires and came in with a 2:26.7 saturday for 4th place (out of 9) & Sunday morning with a 2:25.04 which put me in 4th for the day.
Was busying working/instructing the event and missed the 2nd session and by the third i was just so tired & hot to really do anything worth while.
without looking at data the car definitely has 23's in it. I'm very confident I could get 24's right now tho. Still a few seconds off from the class leader which had a phenomenal 2:19 on saturday and an impressive 2:20 today (reseting the TT2 class record with saturdays time)
Congratulations to @Shortcutsleeping & @GSpeed for the win/record
Also thanks to them I had a car that's only limitations were me!
Also to note, the suspension issue that would randomly show up is now gone with the car higher, which leads me to believe its the ride height simulator thingy.
I would still like increase my front downforce a tad with a slightly larger splitter w/diffusers maybe some wide body fenders to get some wider tires up front but all in all i'm really happy with this weekend
The following 2 users liked this post by lobsterroboto:
daleong (05-06-2019), mfain (05-06-2019)
Old 05-06-2019, 09:32 AM
  #66
STANG KILLA SS
CF Senior Member
STANG KILLA SS's Avatar
saw your car in the back lot. had a lobster sticker on it. assumed it had to be you.
STANG KILLA SS is offline
lobsterroboto (05-06-2019)
Old 05-06-2019, 09:36 AM
  #67
lobsterroboto
CF Senior Member
lol yah that's me. was busy all weekend sucks I wasn't around to chat.
Old 05-06-2019, 12:17 PM
  #68
Shortcutsleeping
CF Member
Congrats on getting some bugs worked out and going faster!!! COTA is as technical as it is power....and getting everything right isn't easy.
I made a prototype C7 splitter for Louis, it has a pretty big lip, is carbon and pretty light. Not a show piece by any means, but might work for you. Basically a C7 version of this:
If you're interested you might ask him if he's still got it...it was a test for some car early last year IIRC, but not sure it made it on that guys' car.
Here is a snap. It ended up just under 9 pounds where the plastic one was 23 and the wood was over 25iirc.
Costas
cars and such...
Shortcutsleeping is offline
Old 05-06-2019, 01:45 PM
  #69
lobsterroboto
CF Senior Member
wow 9 pounds is considerably lighter
I have a new template, I made from MDF already I just need to convert from MDF to something that I can actually bolt to the car.
I would love a carbon splitter, just not able to drop the money right now.
Old 05-07-2019, 01:10 PM
  #70
lobsterroboto
CF Senior Member
Couple of pics from the weekend.
The following 4 users liked this post by lobsterroboto:
daleong (05-07-2019), Kubs (05-07-2019), mfain (05-07-2019), Tool Hoarder (05-07-2019)
Old 05-07-2019, 01:17 PM
  #71
Tool Hoarder
CF Senior Member
Looks badass!
Old 05-07-2019, 05:09 PM
  #72
daleong
CF Senior Member
daleong's Avatar
Looks badass!
I think you're biased to white Z51's though?
daleong is offline
Tool Hoarder (05-08-2019)
Quick Reply: C7 Z51 TT2/ST2 build thread
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
