18x10.5 square, 295/305 r888r or 275/305 nt01?
What do you guys think. Buying four 18x10.5 interlagos +65 for my c7 z51 (Z06 springs, stage 3 aero). Currently running 255/295 r888rs and need more front tire.
Should I get:
275/35r18 front and 305/35r18 rear nt01
Or
295/30r18 front and 305/35r18 rear r888r
The price is very similar. I'd like to try nittos but..What do you guys think?
Should I get:
Or
Sr.Random input generator
Definitely go with the wider front. There's already quite a bit of understeer dialed in to these cars. Wider fronts DO HELP. In a way, using wider front tires is an opportunity, not risk.
NT01s are better than R888R.
i will say this. i ran square setup on my camaro and loved it (60/40 weight distribution)
so when i moved to the (50/50) vette i assumed it would work great. i didnt care for it. had to wait too long to get on power, and wasnt as stable as id like it. lots of tip toeing around. i ended up going back to a staggered setup and would never go back to square.
now i do road course. on autocross i think the square setup could be more usable.
And thanks. I'm wondering if 295/305 on the same wheel will basically mean square and won't gice enough stagger.
With 255/295 I'm understeering heavily. -2,-2 camber. I know several run 335/315 on c7 with good results.
no C7, C6Z here. but square setups have been run on thousands of C5/C6 & C7s.
i ran 315 square, then switched to 315/335
the term square always refers to width. never height. usually the exact same tire F/R
I think you should consider 18x10.5, 19x11.5. the 1" difference at the rear is very significant.
As a point of reference, my 295/30r18 r888r fit on a 10 inch wheel with the section width being a total of 1/2" wider than the wheel.
https://www.corvetteforum.com/forums...post1592974959
FYI, this setup was very robust. If I were to do a narrow body, I'd definitely do 19" at the rear to use the extra clearance from control arms to increase width. You're not putting on much smaller tires, anyway; this is just stretching it properly, and I think it at least gains you another second on a usual track.
Unfortunately, Forgestar are not true custom wheels, and there are certain offset ranges. To start with, most models don't even have 18" sizes available (like CF5V, etc.). You likely need to go with F14.
For F14: https://www.forgestar.com/wheels/rot...ck-series/f14/
There is 18x10.5 available in right offsets for front, but 18x11 doesn't seem to be available in the right offset range for the rears. You need +76 or so.
18×11 offsets from +11 to +55
18×11 offsets from -6 to +43
