ACP Splitter
Location: If you don't weigh in you don't wrestle Road America
I've also installed 4 of the Blackdog bumpers and undertrays and in my opinion it is a much smoother install
The Blackdog set-up you don't have to use their undertray - the bottom of their bumper gives you a flat surface to mount any undertray you want. It is also much easier to make the undertray adjustable - it is also a lot lighter.
After installing both the ACP and the Blackdog - I wouldn't go back to ACP.
The above set-up looks very good and it doesn't appear as though they needed to space out the splitter like I had to.
I probably should have noted that I didn't use the ACP undertray. I don't believe in carbon fiber for something that's expendable so I use a lightweight marine grade plywood called Okume, which has another vendor's carbon fiber diffusers built into it. That allows me to run it all the way back to the bolt holes vacated by the spring perches. Add in a pair of support rods in front and it's strong, adjustable and cheap to replace when needed.
Yes, they have it mounted so that the undertray is adjustable. If I tear this one up I will probably consider going with a homemade undertray. Would you mind sharing whose diffusers you used?
