BBK opinions needed
BBK opinions needed
I’m looking at a couple options for a C6Z. Which route would perform better? A new set of front AP competition brakes using stock rears or a used set of the standard Stoptech ST60 front ST40 rear.
Supporting Vendor
I'm obviously biased, but I've always said you're far better investing in the absolute best front system possible. The fronts take an immense amount of abuse on the C6Z. Your ROI will be the greatest on the front by a long shot. You can always add the rears later when budget or need allows. We've had full-out road racers run our rear kit for years without changing discs...that's practice, qualifying, and racing. Get the best front system you can afford and don't look back.
JRitt@essex (03-14-2019)
Now, approaching season 3 on the same discs. There's a good amount of heat checking now, but they still look like they have plenty of life.
No regrets, these things are amazing. I enjoyed relaxing for a while between sessions instead of working on the brakes. It was short lived though, since now I'm helping my friends bleed THEIR brakes between sessions after they follow me deep into the brake zones.
I have had the 4 piston AP 8350 calipers on the front of my C5 since 2011. Street driven and many track days. I can beat on them all weekend at Road America with full confidence. I would go with Essex.
My rears are stock. I never saw a need to change them.
The current owner of the car I’m buying has a set of ZR1 carbon ceramics that we’ve just about worked into the deal so I’m most likely going to go that route for now. I had the carbon ceramics on my C7 z06/z07 and loved them. I know they will have a higher replacement cost though in the future. Thank you all for the advice as usual. Any suggestions on sway bar set ups for road course? The car have LG G2 coilovers and most likely be running Toyo R888R tires.
https://www.lgmotorsports.com/track-...-swaybars.html
WITH OPTIONAL END LINK PACKAGE
Then you're done.
Then you're done.
