Can't figure out no-lift-shift feature in my 2014 Z51 non-mag
Old 03-25-2019, 02:16 PM
RapidC84B
RapidC84B's Avatar
Received 13,145 Likes on 5,983 Posts
Default Can't figure out no-lift-shift feature in my 2014 Z51 non-mag
I keep hearing "all C7s have no-lift shift". Well mine doesn't... I was at VIR this weekend and had the car in track mode with everything off (hold TCS button 5-7 seconds until both lights come on). I tried power shifting at 6500 and as soon as I'd push in the clutch the RPMs would zing up a few hundred RPM higher and it was like the crap I did as a teenager in high school drag racing. When you'd let the clutch out you could feel the driveline take the hit... it was not smooth as there was no rpm/fuel cut when I pushed the clutch in.
Is no-lift-shift only in PTM enabled cars?
For the record I did not test the car in competitive driving mode as I do not use that and I didn't engage launch control as that's not practical on a road course.
Does anyone know definitively? I've done some google searching and the ask tadge says it's on all the time in all C7s. Mine isn't working... and I don't have any codes and active rev match works fine.
Old 03-25-2019, 03:06 PM
BrunoTheMellow
Support Corvetteforum!
BrunoTheMellow's Avatar
Received 1,395 Likes on 999 Posts
It should work In every mode. Leave tc and stab on and see what happens
Old 03-25-2019, 03:12 PM
RapidC84B
RapidC84B's Avatar
I tired it 3X yesterday on the straights. Track mode, everything off, foot on the floor near 6500 rpm speed shift. RPMS went up to I guess the 6600 rpm cut-off and you could feel the driveline "thud" when clutch was let out. Felt like I was abusing the car and went back to speed shifting letting off the gas quickly. I grew up drag racing and it felt just like "power shifting" when you keep it floored and shift as quickly as you can. I thought NLS would keep the rpms at whatever rpm you pushed the clutch in over 6K rpms, but it doesn't appear to work that way. The Camaro forums has a detailed explanation with tables by former chief engineer Al Oppenheimer (sp?) and he shows there's a min activation rpm and then a target rpm i.e. it's not active until you're over 5K rpm and then the target rpm is 6400 so if you stab clutch in anything before 6400 it will zing there. I guess It's possible I was shifting at 6300 and it was zinging to 6600, but in my mind I was waiting for the blue shift light to blink.
Old 03-25-2019, 03:20 PM
BrunoTheMellow
Here's mine doing it.2015. sounds like fuel cut.
RapidC84B (03-25-2019)
Old 03-25-2019, 03:25 PM
RapidC84B
RapidC84B's Avatar
What rpm are you shifting at?
Old 03-25-2019, 03:26 PM
BrunoTheMellow
6500? just before fuel cut.
Old 03-25-2019, 03:29 PM
RapidC84B
RapidC84B's Avatar
OK... it's possible I was shifting at 6300 and it was zinging to 6600. Would be good to know what the "target rpm" for a Z51 is.
https://www.camaro6.com/forums/showthread.php?t=513327
Old 03-25-2019, 04:02 PM
topmover
topmover's Avatar
Wish I could help, I had no issues with my GS, something has to be wrong unless the Z51 isn't equipped. I just looked at one of my video's and the shifts are smooth not like the old style "power shifting" that you've referred to where you feel like the rev's are going to the moon.
Old 03-25-2019, 04:31 PM
RapidC84B
RapidC84B's Avatar
Originally Posted by topmover
Wish I could help, I had no issues with my GS, something has to be wrong unless the Z51 isn't equipped. I just looked at one of my video's and the shifts are smooth not like the old style "power shifting" that you've referred to where you fell like the rev's are going to the moon.
Some are saying you have to have pressure on the shifter... if it doesn't sense that it just goes to redline. Who knows. Hard to test on street.
Old 03-25-2019, 04:33 PM
RapidC84B
RapidC84B's Avatar
Joe were you shifting at 6200-6300 or at redline 6500-6600?
Old 03-25-2019, 08:37 PM
truth.b
truth.b's Avatar
I was in default mode (turned car off the back on, and didn't realize I wan't in PTM). This shows me NLS on VIR full course at the bridge straight (1:05) and on the back straight (1:35). I was near redline both time and my foot was too the floor and unmoved.
Edit: Just rewatched my clip and towards the end on the front straight NLS worked under approx 6200 RPM.
Old 03-25-2019, 08:42 PM
BrunoTheMellow
Hot Lap Full Course
hmmmm sounds like mine but on PDR you can tell it still spikes to 6750 rpm on "NLS"
Old 03-25-2019, 08:57 PM
RapidC84B
RapidC84B's Avatar
Thats exactly what mine does.... 6400 shift to 6700 spike.
Old 03-25-2019, 09:01 PM
RapidC84B
RapidC84B's Avatar
Hot Lap Full Course
Thanks for sharing, but every shift I saw the rpm jumped into the red over 6500, which is what mine did.
Old 03-25-2019, 09:03 PM
RapidC84B
RapidC84B's Avatar
Maybe mine is working then.
Old 03-25-2019, 09:35 PM
BrunoTheMellow
Hah I guess NLS is just banging the redline.
Old 03-25-2019, 10:53 PM
truth.b
truth.b's Avatar
To me the big difference with NLS is what I'm doing with the accelerator and how it sounds. I know for NLS my foot had to be all the way to the floor and steady. When it was the shift sounded like a reverse rev-match.
Heres the full session of the above C7 clip was taken from. Ignore all the taking, it was my first and only time driving a C7 Z06 at track and it was a good one
Here's a clip of me in my car --> C6 GS.
To Can't figure out no-lift-shift feature in my 2014 Z51 non-mag
Old 03-26-2019, 07:06 AM
Poor-sha
Track Rat
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
Pretty sure I responded to you on FB but here is what I think.
I don't believe NLS does anything to control the revs, it just modulates the engine torque so you don't hammer the driveline when you let the clutch back out. The revs definitely jump when you push the clutch in. There is a fuel cut but the inertia will make them jump a bit more - 6700 RPM isn't unusual but there is no load. I can't say I've ever felt a "hit" to the driveline but sometimes there is a brief bog like the TC kicked in.
RapidC84B (03-26-2019)
Old 03-26-2019, 07:41 AM
topmover
topmover's Avatar
Redline...………….also I only used it in 3-4 shifts.
Old 03-26-2019, 07:44 AM
topmover
topmover's Avatar
I think this is the best explanation I've seen.
Quick Reply: Can't figure out no-lift-shift feature in my 2014 Z51 non-mag
