Help MAJOR Engine Failure seeking advice and options
Old 05-11-2019, 10:32 PM
DunlevysZ
CF Senior Member
DunlevysZ's Avatar
I think a lot depends on how much trash got up between the pistons and cylinders.It could possibly be limited to a crank and a rod or two, but it's just guessing until the tear down.
DunlevysZ is online now
truth.b (05-11-2019)
Old 05-17-2019, 05:59 AM
K.I.T.T.
CF Senior Member
K.I.T.T.'s Avatar
Sounds like 427 time if ya ask me!...lol.
K.I.T.T. is offline
Old 05-17-2019, 06:19 AM
449er
CF Senior Member
449er's Avatar
If you go with the new crate engine option, GM sells the LS3 in different horsepower variants...I believe they have a 500 + hp version with a warranty
449er is online now
Old 05-17-2019, 03:10 PM
Under-Pressure
CF Senior Member
Under-Pressure's Avatar
Under-Pressure is offline
Old 05-19-2019, 04:24 PM
ponycar
CF Member
Hey Truth, I've met you at the track, we have mutual friends. I've seen either Jegs or Summit, can't remember which, sells a dry sump LS3. Good luck with the build. I hope you'll make NCM VIR. David
ponycar is offline
Old 05-20-2019, 09:47 AM
93Polo
CF Senior Member
93Polo's Avatar
CI 3-4-5-9 Veteran
We were in the same boat a couple of years ago. We talked to the owner of Vengeance Racing and he did have take out low mile motors which were replaced with more powerful custom builds. I'd give them a call to see what they have. More than a few have done expensive custom builds for the motor to fail and you kept a stock motor alive for a long time.
93Polo is offline
Old 05-20-2019, 09:56 AM
93Polo
CF Senior Member
93Polo's Avatar
CI 3-4-5-9 Veteran
Originally Posted by andersnor View Post
525hp ls3, gm warranty
https://www.jegs.com/p/Chevrolet-Per...41625/10002/-1
tanks should be cleanable
oil cooler I would not risk, same with lines
Originally Posted by DunlevysZ View Post
Just to be clear, you're running the factory GS dry sump?
Originally Posted by truth.b View Post
Yep. My car is a 2013 Grand Sport manual coupe.
I would upgrade to something like the Aviaid LSA dry sump with their pan or stock pan with Improved Racing Crank scraper but I have not run a dry sump motor. Maybe someone will step in.
Also the crank snout and oil pump on the LS3 dry sump is not the same as the standard LS3. Something to consider when looking at crate motors. You could still run the LS-A system for scavenging and a factory wet sump oil pump for pressure.
93Polo is offline
Old 05-21-2019, 06:51 PM
AND0
CF Senior Member
We all know that the LS is the greatest engine ever made, but.... repeated trips over 7000 at the road course on a factory engine with 120,000 ++ miles....
It might not be that anything specific caused this failure other than end of life cycle for components. Pistons fatigue, faster at high RPM.
If you go with a factory crate LS3 maybe consider a lower RPM limit, or an aftermarket build with forged lighter weight components.
You certainly got good use out of this engine.
AND0 is offline
Old 05-23-2019, 07:27 PM
AJ02
CF Member
Support Corvetteforum!
AJ02's Avatar
C6GS, Recently had to rebuild my motor due to spun rod bearings and crank. A couple rockers blew apart and sent needle bearings through the system and we expect oil starvation. Went back in with a 416 stroker kit and BTR stroker cam. After researching all of the costs, they're all about the same at the end, but came out of it with 510 rwp/ 495 tq. The block, heads and top end were saved, but replaced everything else.
Dry sump and lines were cleaned out, but replaced oil cooler. We did add the scavenger tray. Let me know if you have any questions about the build.
Car is tracked pretty regularly and sees high rpms for 20-30 minute periods.
AJ02 is offline
Old Yesterday, 07:10 AM
truth.b
CF Senior Member
truth.b's Avatar
Pardon the redumentary question, but what is a scavenger tray and what was the benefit of adding it.
truth.b is offline
Old Yesterday, 07:35 AM
AJ02
CF Member
AJ02's Avatar
Not rudimentary at all...I had no idea until my builder suggested it. Below is an excerpt from Improved Racing's site.
Improved Racing's crankshaft scrapers help reduce oil starvation by closely contouring the crankshaft and rods to remove excess oil, ensuring oil is quickly returned to the bottom of the sump. Crank scrapers also help reduce parasitic drag and windage losses caused by excess oil on the crank, which reduces rotational mass and results in dyno-proven gains of 5-10 HP at the wheels.
AJ02 is offline
Quick Reply: Help MAJOR Engine Failure seeking advice and options
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
