What wheels are you running with a BBK on C5?
This is turning out to be more challenging than I was originally thinking. I haven't bought my brakes yet - looking at the Stoptech ST-60 or Wilwood Aero 6. Currently running 18x9.5 Z06 replica's on the front and looks like I may need a small shim to clear them (probably ~0.100" should do it but can't find anything thinner than a 1/4" and don't want to go that thick). Is anyone running wheels that clear a BBK that don't cost $6k for a set (besides OE rear Z06's)?
There are a few relatively inexpensive options...
Kirk
- Stock C5Z06 18x10.5 on all four corners
- TSW Interlogos or TSW Nurburgring 18x10.5 +65 on all four corners
- Forgestar F14 - Least expensive custom widths and offsets
Kirk
87GN&98VET (05-24-2019)
Supporting Vendor
We offer several Essex Designed AP Racing Competition Brake Kits that will clear OEM 18" rear C5 Z06 wheels when run on the front of the car. I've listed three of them below, from the smallest/least expensive to largest/most expensive. I also threw in some other wheel fitments that work. Before you pull the trigger on Stoptech or Wilwood, be sure to check out our kits. They are more expensive on initial purchase, but you also get a lot more for your money over the long haul. These cars devour front brakes, and it's always a good idea to invest in the best front brake system you can. It will save you a boatload of money in the long run.
Tons of owner feedback on our blog and elsewhere here on this forum. Thanks for your consideration, and don't hesitate with any questions! We have been a forum sponsor for many years and will jump through hoops to keep you happy.
Owner reviews on our blog:
https://www.essexparts.com/news-blog
Lots of Corvette owner pics in our gallery:
https://www.essexparts.com/media-center/photo-gallery
I'll include some pics of each kit below so you can get a frame of reference on disc vs. wheel size.
CP8350/325mm
https://www.essexparts.com/essex-des...cp8350-C5vette
Confirmed wheels that fit without a spacer:
Inside an 18
CP9660/355mm
https://www.essexparts.com/essex-des...mm-c5-corvette
David Farmer's car with our 9660/355mm kit on his C6:
Another beautiful C5Z with our 355mm front kit (and rear 340mm):
CP9660/372mm
372mm inside an 18.
CP8350/325mm
- OEM front 17" C5 Z06
- OEM rear 18" C5 Z06 when run on front
- TSW Nurburgring 17x9 +50
- TSW Interlagos 18x9 +50
Inside an 18
CP9660/355mm
- OEM C5 Z06 Rear 18x10.5" Speedline wheels when run on front of car
- Forgestar 18x11, 7.75" backspace
- Enkei NT03+M 18X10.5 +64mm offset
- TSW Interlogos 19X10.5 + 65mm
CP9660/372mm
372mm inside an 18.
Hey Sean - I'm running C5Z rears on my base C6 with the Wilwood Aero6 Race brake kit but seriously thinking about getting a set of F14s. They're about the same cost to buy new and the F14s look much better in my opinion.
-Matt
-Matt
TSW Nurburgring 18*10.5 +65 clears my ST-60 brakes with room to spare.
BigMonkey73 (06-02-2019)
Can you quantify "room to spare"? I run standard CCW C10's, 18x11 over massive AP Calipers (29 mm pads) and they clear. C5 rears also clear (barely) and C6Z fronts require a 1/4" spacer. I am looking to get wheels for a wet setup, and the Nurburgring's are a candidate.
The car is at a shop right now but if I remember right I was able to get a finger between the caliper and the spokes, so at least 10mm, maybe 15mm.
I also have C6Z repro fronts, so that might be a good reference. They're 18x8.5, +56, and they needed a 15mm spacer to clear the brakes. With the spacer they only clear by about 4mm. (Street use only, no sticky tires.)
Supporting Vendor
As others have mentioned. TSW Nurburgring or Interlagos. I run them on my car with AP BBK. I am a dealer for TSW. You might have a hard time finding a set now. I have several sets on the way that should be here the end of June.
Thanks for the info on the Nurbergrings. I mis-typed on my C6Z wheels, they are actually "just" C6 wheels, 18x9.5, +57 (I believe). With the 1/4" spacer they clear, very tight. I have no issue using them on the track for a wet/drying setup - typically a decent wet street tire like the Toyo R1A.
