C7 Grand Sport FE6 to FE7 (Z07) - info sharing
#121
A quick glance through a few catalogs suggests that you're correct. The Z06 FE6 spring is different than the GS FE6 spring. Not surprising since they need to address the extra 100lbs over the nose when setting ride height. I'll be at the track on Saturday and one of the guys I'll be there with has a 2017 GS Z07. I'll snap a pic and if the p/n info is still visible I'll post it
#122
Excellent. So same part number as came on my 19 and your 19 FE6 GS cars.
badhabit_wb (11-10-2019)
#125
11612295 Axle Nut $6.88
11516078 Stabilizer Link Nut $3.59 8 $28.72
Part Number Part Name Price Quantity Total
20966781 Stabilizer Bar $77.94 1 $77.94
22936510 Stabilizer Bar $81.52 1 $81.52
84144988 Spring $189.85 1 $189.85
23344290 Spring $209.91 1 $209.91
23305978 Stabilizer Bar Bushing $9.83 2 $19.66
23305974 Stabilizer Bar Bushing $6.11 2 $12.22
11546672 Stabilizer Bar Bolt $2.63 8 $21.04
3545602 Spring Bolt $3.57 4 $14.28
#126
GS uses the same rear sway bar for FE6 and Z07 (FE7) set ups. Front spring is also the same for FE6 or FE7 Grand Sports.
Bushings (ie insulators) are different for the FE7 GS cars and are listed in the screen shot. The GS Z07 front bushings are not the same as the Z06 Z07 cars since the front sway bars are different sizes.
