Will the later tach drive distributors w/vac advance work for a '62 Corvette tach
Old 04-29-2005, 01:55 PM
wesmigletz
12.14 w/ the original 327
Support Corvetteforum!
wesmigletz's Avatar
CI 8-9-10 Veteran
St. Jude Donor '07-'08-'09
Default Will the later tach drive distributors w/vac advance work for a '62 Corvette tach
I'm interested in adding a GM tach drive distributor with vacuum advance to a '62 corvette I just picked-up. The car currently has a dual point with mechanical advance.
Will any of the later Corvette tach drive distributors with vacuum advance work with a 1962 corvette tach? If not, is there a later tach that will fit and look OK in a '62 housing? Are any years better, or should certain years be avoided? Will a MSD tach Drive p/n 8572 work? My first choice would be to run a GM distributor, but I would consider the MSD as an option. TIA Wes
Old 04-29-2005, 01:59 PM
Dave62
Dave62's Avatar
Short answer.....yes they work with no issues. Just set up to your engine for advance curve.
Dave62
Old 04-29-2005, 02:53 PM
wesmigletz
wesmigletz's Avatar
CI 8-9-10 Veteran
Dave, thanks for the information. Wes
Old 04-29-2005, 08:45 PM
SWCDuke
SWCDuke's Avatar
Received 1,974 Likes on 1,188 Posts
Be sure to select a vacuum advance that is properly matched to the engine's manifold vacuum characteristics. This has been discussed many times in the past.
Duke
To Will the later tach drive distributors w/vac advance work for a '62 Corvette tach
Quick Reply: Will the later tach drive distributors w/vac advance work for a '62 Corvette tach
