bown head gasket
bown head gasket
I took the left head off today. The cylinder that has 65psi has a blown head gasket on the lifter vally side. This explains where all of the oil is going.Im going to put on another head gasket...do I need to do both sides?.....Also there is a number stamped into the block on a milled pad front,center. The number is T05I0XCH. What is this no. If it is an engine ID does anybody know what it is.
thanks Jeff
thanks Jeff
