Lube for tach and speedo cable?
i installed new tach and speedo cable as part of my restoration.
should i have put some kind of lube on the cables? if so what kind?
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,924 Likes
Believe it or not, but there is actually such a thing as speedo cable lube. You pull the cable out of the housing/sleeve and wipe a thin coat of the lube on it. It's available from most parts stores in a small tube.
Received 3,768 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
No doubt there is a "special" lube for speedo cables. But, as far back as the Civil War, I've always used a good chassis grease with ZERO problems.
Going from memory again (which is a dangerous thing for me!!!), I believe the main difference in the speedo cable grease and chassi grease is that the speedo cable grease has some graphite added.
(As I seem to recall . . . ) Either will work well, I suspect. PS Most instructions I've seen tell you not to lube the upper 3-4 inches of the cable at the speedo head!!
Ron
thaks again to forum members.
i have asked two questions in the last 2 days and the total wait time for an answer is 7 minutes.........huge help
how hard is it to replace speedp and tach cable?
HI cable guy/s and or gals. I am considering buying a 63 SWC that the owner said needs speedometer and tachometer cables. Assuming that will fix the inop gauges, Is this an easy fix or does the whole cluster come out? $ for parts estimate? .
