Very Cool Man-A-Fre 4-carb Manifold - 427 BBC
I was goofing off on Ebay and did a search on Man-A-Fre....
I've seen the 4- 2barrel carb set ups for Small Blocks but never a
Big Block.... ad says the guy has the linkage too..
http://cgi.ebay.com/ebaymotors/427-4...QQcmdZViewItem
St. Jude Donor '07
i had a Man-A-Fre on my '65 327, once-upon-a-time. it was the greatest thing since FI, without some of the hassles that goes with FI.
funny thing is, i traded it for my first FI; i wish i still had it, but all the units i see selling on ebay are VERY expensive.
i even wrote to Man-A-Fre recently (they are still in business, making off-road parts for Toyota's (i think)), but i was told they scrapped all their molds a while back....
Bill
Bill
BBC Man-A-Fre Recent Build
Just finished a 396 BB with G.M. Aluminum heads and an Engle solid lifter setup. Customer requested the "Man-A-Fre" be used. Unit performed flawlessly.
The purpose of this build was to use some "old-school" components but combined with today's technology, the PCV setup.
As you can see from the photo below it's really quite impressive looking for a multiple carb setup. If you look closely you can spot the "Moon-Eyes" V/C breathers.
(Add) Unit made over 500 HP on 93!
Thanks, Gary in N.Y.
P.S. There was much add'l engineering done on this particular build. As I stated above, the customer also requested us to use a 2006 Vette "hidden" PCV system. You cannot see from the photo but it has the entire system below the intake manifold. Took some hours of machining but it was finally accomplished. It is 100% functional AND 100% "invisible". Not a single visible "hose" or line connected. Gets fed directly from the "valley" into the underside of the plenum.
Received 2,339 Likes
The carbs (frozen) are listed separately
http://cgi.ebay.com/ebaymotors/Man-A-Fre-Original-4-Rodchester-Carbs-Frozen-Carbs
The seller also has an interesting small block item - Ansen main straps?
http://cgi.ebay.com/ebaymotors/327-Chevy-Main-Straps-NOS-NIB-Made-By-Ansen
Anyone remember how these work (did they help)?
Bill - It was a cam, not a distributor. It had double lobes. The special timing gear compensated for the slower turn of the cam. Like the Man-A-Free, it too was more theory than reality as far as improvbed performance
St. Jude Donor '07
Bill
Either way, the cam set-up really made no sense as far as gaining anything. We actually ran better when we pulled out the stroker engine the cam was in and swapped it with a stock 327, 340 hp short block ,
St. Jude Donor '07
Bill - Maybe they had a couple of set-ups, but I don't remember the dist being different. We bought a short block that had that cam and don't remember using a different dist, but then that was over 40 years ago and I'm sure I've forgotten a lot of other stuff too since that time.
Bill
it was neat to look at though....
they work, they strenghten the bottom end main cap studs in a
similar way that a rev kit strengthens your rocker arm studs...
pieces of metal that tie the studs together so that there's less flex...
.... stiffening the bottom end.... you get more support from a girdle
than a strap... not nessasary unless you're going to make over 500hp.
but deffinately cool to see the old Ansen stuff out for sale...
PRW stud girdle....
Straps usually just tie 2 studs together .... not all the studs like a girdle.
A Girdle would be something you could use instead of drilling for Splayed Main Caps on a 2 bolt motor.
