ok. i know we have beat this to death. but serious question here. i switched from synthetic 10w 40 to regular 20w 50 and my engine seems less aggressive. now i know some of you are thinking, bogus, but seems like it is kinda sluggish a bit and doesnt rev as high as easily. am i nuts. perhaps. but think i am going to switch back. i know if it is not broke, dont fix it. thought about a bit heavier for summer driving heat to protect engine. dumb maybe.
I've always thought that conventional oil was more than adequate for older engines. I have however used synthetic in my wife's Cadilac's and Lexus. Only had my 63 a few years and I use Castol 10-40 with no problems. I thought that using synthetic in an older engine would increase the possibility of leaks. Anyway, you are absolutely correct, if it ain't broke, don't fix it. Go back to your original oil. Enjoy the ride!!
always used mobil 1, but castrol is right there. considering a blend. just thought that it was wierd. i mean, never thought oil would make a difference. shows my ignorance. a nice compliment from a car that is wayyyy nicer than mine.
i tried to search but was not getting any matches. funny cause i know this subject has been beaten to death. maybe new server not complete. will try again.
The heavier oil could indeed make some difference in the spin up of the motor, and could cost you 5-10HP, but your butt dyno would have to be pretty sensitive. It is also possible your oil level is a bit high or the windage parts are not in the motor causing windage loses which maybe be more extreme in the thicker oil...maybe to be point of aerated oil causing minor lifter collapse and thus more power loss. All that is kinda extreme but it is 'possible' though not likely.
yea, i had two small leaks with synthetic. but going back to 10w40 synthetic. tomorrow.....
FWIW: Synthetics do not cause leaks. I run 5w-40 Rotella syn in my Corvair which has Thirty Six more places for oil to leak than a small Block.
Only leak it has is the drain plug, it needs a new gasket.
Edit: A small block has none of the following.
Push rod tubes 2 x 12 = 24
Rocker studs ...............12
Oil cooler rubber donuts...2
Oil cooler adaptor gasket..1
Total ..........................39
I'm just a little bit familiar with Corvair engines and at least 24 of those possible leak points are sealed with 0-rings on the ends of the pushrod tubes going into a machined housing instead of cork clamped between two less-than-perfect mating surfaces.
You are correct. Synthetics do not "cause" leaks. They simply clean out areas where there had been a build up of crud where oil could not pass through and allow oil to now pass through those areas that were previously closed off due to the build up of that crud and escape from the engine.
Don't get me wrong as I LOVE synthetic oil and use it in all my vehicles.
mispoke. entirely. they are not the cause. but they do expose more leaks. for the reasons stated. have had many cars that have had conventional and once i switch over to synthetic, i get some leakage. it was not showing overfill and it was not severe, i just noticed it. so, last night i drained it and mobile 1 10w40 back in. engine happy again. spools up much quicker and easier. i can mostly hear the difference out of the chambered exhaust. now, is anyone else having trouble doing a thread search? i am getting no results even typing in something like oil.
I use a standard 10w30 in my C-2 and 10w40 in my C-3. I am using 5w30 in my Street Rod being it is a later model GM Crate motor calling for it. If the motor doesn't have much mileage say after a rebuild I would use 10/30. Either the 10w30 or 10w40 one will do the trick in these cars. The jury is still out on the synthetic as far as I am concerned. Being in the business nothing has convinced me from what I see everyday that it is any better.
