Martz Chassis C1 front suspension
Old 07-15-2008, 07:01 AM
  #481
firstgear
Support Corvetteforum!
firstgear's Avatar
2019 Corvette of the Year Winner
St. Jude Donor '15
Originally Posted by 62rat
Bill,
I know it needs more caster but the alignment guy said he put in all he could. Before I put the suspension in I called Martz and asked about the shims that were between the stock suspension and the frame. They told me to leave them out. I suspect that those shims might solve the problem. I probably have about 1200 miles on it now and everything has been great. It drives fine, handles good and doesn't seem to be wearing tires at all. The fact that it doesn't have a sway bar does not seem to be any problem at all.
I finally learned how to post pictures.
I put mine in with my Meyers IFS...
firstgear is offline
Old 07-15-2008, 07:40 AM
  #482
Stan's Customs
Stan's Customs's Avatar
I want to post a picture of the steering linkage. It took Ididit four tries to get me the right length column but it all worked out real well after that.
Pretty slick, huh?
Bob
That is pretty darn slick!..Looks like the angle on the shaft is real good...no sharp bends and a minimal amount of knuckles.
Also, it is nice to hear that you are having no issues because of the absence of a sway bar...please let us know if that changes. That was one of the things that was worrying me about several of the IFS offerings.....not that it couldn't be fabricated. I just thought they should have included it in the kits to save us the hassle if it was needed.
Glad you have had good results...I'm envious of your progress, hope to get mine started very soon.
Curious to know what you think of the big block in a C1...has that worked out well? I've always had big blocks in the majority of my old cars. But I decided that this one would be the exception.
Stan...
Stan's Customs is offline
Old 07-17-2008, 09:36 AM
  #483
62rat
62rat's Avatar
Originally Posted by Stan's Customs
Bob
Stan...
Thanks Stan, I know how you feel. There was a time there when I didn't think I would ever get my car back together either.
I have no issues with the Martz suspension other that the things that I mentioned perviously. They said that I would not miss the sway bar and so far that has proved correct. I'm sure that the new suspension has taken a good amount of weight from the front of the car although I never was able to get a scale to find out what the difference actually is. Martz's workmanship is exceptional.
As for the big block, when I bought the car nine years ago the big block was already in it. I have no experience with small block Vettes. I enjoy the car now and would not even consider putting a small block in it. It has all the power I need and more than the current tires can handle if I really get on it hard. I don't know what the weight difference is between an aluminum head big block and an iron head small block but this car does not feel at all nose heavy to me. I told Martz that I had a big block when I ordered the suspension but I don't know if they did anything different because of that.
I know you have been researching all this for a long time and I'm sure that when you finally get it done you will have it the way you want it.
Good luck on your project and keep us posted on your progress.
Bob
62rat is offline
Old 09-01-2008, 01:59 AM
  #484
sss3d
sss3d's Avatar
That's really great.
sss3d is offline
Old 09-01-2008, 01:17 PM
  #485
solidaxel
solidaxel's Avatar
Originally Posted by Merlin496
Thanks to 62JEFF for the welcome and thanks to Bill for the pics of the rotor/spindle
62 JEFF, what is the assembly from Mll, it looks like Ford?
Is it part of the kit?
solidaxel is offline
Old 09-01-2008, 01:25 PM
  #486
62Jeff
62Jeff's Avatar
Don't know, all I did was welcome the guy to the forum.
62Jeff is offline
Old 09-01-2008, 01:29 PM
  #487
solidaxel
solidaxel's Avatar
"Sorry", wrong guy!
Old 10-22-2008, 03:55 PM
  #488
cardozob
cardozob's Avatar
Default FLorida living
Originally Posted by Plasticman
Gordon & Ken,
Not by much! But Bill (wmf62) really does appreciate the AC in my shop (and I do a "little" )! And frankly, we both admit that doing the TCI without a lift would be a lot harder!
Plasticman
DEFINITELY THE WAY TO GO!!
www.reliablecartransportation.com
cardozob is offline
Old 01-01-2018, 02:00 PM
  #489
1959corvette
1959corvette's Avatar
I am reading all this, and still dont know which is the easier one to install
1959corvette is offline
Old 01-01-2018, 02:03 PM
  #490
1959corvette
Gordon,
I am sure we can write "something" up (later, after full completion). And yes, welding skills are necessary with the TCI. There are several other issues that, while they (or we) have solved each one, has taken a lot more engineering and rebuilds (and time!) than necessary for a "kit".
Plasticman
Plastic man
you seem to know alot about these replacement front ends.
any verdict which is prefered
Old 01-01-2018, 03:17 PM
  #491
vettebuyer6369
vettebuyer6369's Avatar
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,318 Likes on 2,767 Posts
You are responding to a 9+ year old post.
If you have a question, consider starting a new thread.
vettebuyer6369 is offline
Quick Reply: Martz Chassis C1 front suspension
