Marvel Mystery Oil in Fuel?
#101
1% lard???!!!
Maybe thats why it keeps GTOguys leather accelerator pump diaphrams supple?
#102
Received 6,513 Likes
C2 of Year Finalist (track prepared) 2019
In the case of the high pressure pump in Rochester FI, however, the best corrosion inhibitor is regular, frequent use.
#103
Received 1,843 Likes
I have used MMO to good advantage. It's an excellent penetrating oil and I have known it to free up sticking valves in small side valve engines on several occasions. For a fact. Don't know about OHV engines. Never thought I needed it.
Automatic transmmision fluid works much the same way. Like Dexron II,III.
#105
In the early 2000s, there was an aircraft engine failure that the NTSB stated that MMO as a fuel additive was the probable cause. The NTSB tested a sample of MMO and found it was 74% mineral oil, 25% stoddard solvent, and 1% lard.
If you use it in your car, whatever. If you use it in an aircraft engine, I’d make damn sure it’s approved by the engine’s manufacturer.
#106
With modern oil formulas l really don't see a need for it any more. The only additives I use are Techron and StaBil.
My penetrating oil is acetone and tranny fluid.
