C1 clock removal
Old Sep 19, 2007 | 10:37 AM
x0000rgw's Avatar
x0000rgw
Default C1 clock removal
I have the 4 nuts removed from heater faceplate and it pulled out
about 1.5 inches. Can not see what holds the clock in. Does it twist out or am I missing something.
Old Sep 19, 2007 | 10:47 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
yep, it twists,,, i forget which direction and think you have to push while twisting; but if you look carefully at the back you should be able to figure it out.
Bill
Old Sep 19, 2007 | 10:52 AM
x0000rgw's Avatar
x0000rgw
Thanks Bill,
Now I can see the beveled edge at the front of the clock ( from the
rear) Looks like you twist counter clockwise.
Old Sep 19, 2007 | 10:53 AM
kenmo's Avatar
kenmo
It twists out. can't remember clock wise or counter clockwise...
Old Sep 19, 2007 | 02:38 PM
x0000rgw's Avatar
x0000rgw
Thanks Ken,
The clock must be pulled to the back ( toward the firewall). Then you rotate it clockwise (turn to right). Then it pulls out the front. There is a
waffle spring that must be collapsed by pulling it back.
Thanks for the help. I'll clean it up and see if it will work.
Ray
Old Sep 19, 2007 | 10:31 PM
devildog's Avatar
devildog
From: fighter pilots make movies, bomber pilots make history
Thanks for this info, I have been thinking about pulling mine for the past 25 years. Now, I am motivated.
Joe
To C1 clock removal
