rear end whine
At 50mph you have to raise your voice and at anything over 40mph it is loud enough to dwarf the exhaust note.
If you decide that is the route you are going to go, be prepared to refurb your cross member and strut rod bushings. Look hard at your axle shaft u-joints, too. Depending where your car has lived, both shock mounting brackets may have to be replaced as well as your camber bolts.
