Re-chromed Tail Light Bezels
I need my tail light bezels re-chromed on my 59. The outer lip looks good but the inside under the lens is not that great. Who does a good job on these? How much can I expect to fork over for it?
As I understand it it takes special equipment to re-chrome the inner section and many re-chrome shops can't do it. I had my outter portion re-chromed and then sanded and painted the inner section with metalic paint. Once the lense is on they look great. But as mentioned by others you are probably better off buyong a new set if you want the inner section re-chromed.
I knew it wasn't going to be cheap. I'm in Alabama and checked on it a few years ago when I restored the car. Nobody around here could do it. Reproductions don't come cheap either. I just thought I would check out everybody else and see what they were doing.
