CAN ANYONE HELP IDENTIFY THESE HIGH PERFORMANCE PIECES?
I"m tearing down a small block that I removed from an old Vega drag car. The previous owner couldn't tell me much about the engine so i'm trying to I.d. the markings I found on some of the pieces. If you don't know any specs, just the manufacturers name would be helpful. Here goes: Torque Converter- P8731 AFCXLS (about 9 in. turbo 400). PISTONS- H617P CAMSHAFT-119526 8H1B (roller). The rocker arms are Crane. Some are stamped 411D and some are H790. Are these 1.5 or 1.6 ratio? I looked in all the catalogs I have but wasn't able to match any of these numbers up. Any and all help would be greatly appreciated. Thanks guys! P.S. I also posted this in the high performance engine section.
Re: CAN ANYONE HELP IDENTIFY THESE HIGH PERFORMANCE PIECES? (Cruz 86)
The pistons are 350 Chevy TRW Hypereutectics,with .275 domes
About 12:1 with 64cc heads
Bob
Bob
Re: CAN ANYONE HELP IDENTIFY THESE HIGH PERFORMANCE PIECES? (Desertvette)
Thanks for the input Bob! I think the cam might be either Crane or Erson. If anyone has either of thier catalogs could you please take a look? Thank you!
Found out the cam is a Lunati piece. How about some help on the torque converter and rockers. Thanks .
