Wanted: Easy to buy hi-ZDDP oil
#41
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
FWIW, old threads are closed all the time in OT.
http://forums.corvetteforum.com/foru...s-or-more.html
#42
Which is why I tell people that nothing they post, tweet, email or text EVER goes away....all that blather can come back to haunt you when you least expect it !
#43
Hey everybody! New forum member here who wants an opinion or two on motor oil for a 1963 fuelie. The car has a fresh rebuild on the motor (maybe 5,000mi) and I am looking for the preferred synthetic oil weight to use. Please be easy on me...I come from a BMW background and this is my father' scar. Unfortunately he has dementia and although this car is highly documented, there is no specifics in regards to what weight oil was used. Being a solid lifter car, I want to make sure it's properly lubricated. I have a few people to contact as of yet but I always like to get the opinion of the internet community. Many thanks in advance!
John
John
#44
Oil
My '61 has solid lifters - need I say more...and I don't want to ignite an old thread on this topic and bore everyone. But, I need an easily available source of a Hi-ZDDP oil (I don't want to use additives) - I have CarQuest, Napa, AutoZone, Advance Auto, WalMart etc. nearby. Do any of these guys have what I need ? Does the Valvoline Motorcycle 4-stroke oil do it ? I want a brand name please that is in one of the stores mentioned - don't just tell me to find some diesel oil. Thanks in advance.
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
Cheers
T
#45
Cited most often is that non-roller cam wear is reduced if the oil has high levels of Zinc/ZZDP. Valvoline VR1 has worked well for me. Certain diesel oils contain high levels and are often recommended. Look for a service rating of CI-4 or CJ-4...
Harry
Harry
#46
I am using Mobil 1 5W-50 bought at Wal Mart in my 67. 1100 PPM. Easy to find! Here is a pdf that shows what all the Mobil 1 oils contain.
Cheers
T
Cheers
T
#47
i've been running 20/50 Valvolne Racing oil in my car for years.
#48
The resurrector of this two year old thread specifically asked for recommendation for synthetic oils.
#49
Received 1,843 Likes
Since he's used to the BMW stuff that uses synthetic, maybe he thinks it's REQUIRED? Why spend money when there's no need to?
Rotella T diesel oil is available in the viscosity grades as listed in the owner's manual.
I'm not sure using an oil with a viscosity range of 5 is a good idea if the engine was built to original factory spec.
#50
I don't know if you're going to find a true full synthetic with enough zinc. Although just about everything out there is basically a synthetic blend labeled conventional anyway.
#51
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
http://www.walmart.com/ip/Mobil-1-15...Quart/20713647
-- Steve
#52
Cruise-In II Veteran
Cruise-In III Veteran
I use Amsoil. They have a special synthetic oil for classic cars with high ZDDP. I love it and I'm not an Amsoil distributor I will say upfront.
However, I got an Amsoil account so I order my stuff online and it is shipped to my door. Great product!
#54
As we have all painfully learned -- no one post ever "says it all" about engine oil. There are terabytes of posts on the forum on just this single topic I'm sure...
#55
Or, you could really go overboard and use Harley Davidson "full synthetic" 20/50 motor oil. It's designed for use with their babbitt bearing engines - LOTS of zinc and phosphorus additives - 2% according to their specs, which is 2000 ppm.
It's only $12.95 a quart or $48.95 a gallon...........
When only the best will do!
Funny thing is, their spec sheet also says it's actually a blend of 60% synthetic and 40% petroleum oil...........
It pays - literally - to research a product before you buy it!
#57
I get a bigger kick out of bloggers having repetitive & overwhelming concerns establishing age of thread rather than contributing to it, just like expired milk... "Don’t drink it or your babies with be born naked" type attitude.. ha ha ha!
Oh and MikeM, I stated repetitive, same as tediously or repeating in addition to overwhelming so no need to extract an older thread that I post reminding you (only once) that it was an old thread.
rustylugnuts
rustylugnuts
#58
You've lost me. I don't care if it's an old thread or not. I read the owner's manual.
#59
Oils spec'd for old engines were spec'd for a reason. If they are built to the old spec, best the owner find an oil that meets those requirements. The requirements haven't changed either.
Based on what little I know about oil formulation, some of these oils being recommended here would fall short of the original requirement.
What else ya' got?
