carb tuning question
On a holley DP should there be any clearance between the acelerator pump levers and the adjustment bolts with the carb in the closed position?
Jeff
Jeff
Re: carb tuning question (jeff batchelor)
The accellerator pump lever to diaphragm clearance is chkd at wide open throttle. Should be.015. This is to insure diaphragm is not stretched
Bob
Bob
