Mine also had two, however my mechanic suggested that two
increases the tension in that area and can cause some type of internal damage to the carb over time. Maybe someone else can explain in more detail. I just run one now and carry a spare.
If the one spring is in good condition, not fatigued, I don't see any reason for the second. Now if you are a racer with heavy duty s-it, maybe a second one to make sure the throttle returns in case there is some kind of issue
There was 1 on my 66 but as I tryed to start it Sat. it broke while I was pumping the gas peddel before it started. There will be 2 on there from now on and also on my 63 coupe also.
Black Magic, That is beautiful, hard to see the springs with all that chrome. NICE job. I'm going to my FLAP store to get a smaller diameter spring to fit inside the large one I have. Thanks to all for your input. Bill.
