1965 Courtesy and Parking Brake Switch
Old 05-27-2008, 05:32 PM
Mikey65
CF Senior Member
Default 1965 Courtesy and Parking Brake Switch
What is the correct way to attach the wire from the harness to the switch itself? Does it just crimp on there??
Mikey65 is offline
Old 05-27-2008, 05:54 PM
62Jeff
Support Corvetteforum!
62Jeff's Avatar
Wires for each of those switches have a bullet-shaped terminal. The terminal pushes into the female connector on the switch.
On my 65 I pushed until I felt a little "snap"
62Jeff is offline
Old 05-27-2008, 05:59 PM
DZVette
CF Senior Member
DZVette's Avatar
The "bullet" connector just plugs into the "receiver" (the round socket on the moving end of the switch) on the switch. At least that's how my courtesy light and P-brake warning switches connected.
DZ
DZVette is offline
Old 05-27-2008, 07:32 PM
Mikey65
CF Senior Member
The wire doesn't want to just plug in there... no matter how much pressure I use to try to plug it in, it falls right out.
Mikey65 is offline
Old 05-27-2008, 07:35 PM
62Jeff
62Jeff's Avatar
Then either the remains of the old terminal is still in there, or the female connector needs a little squeeze from a pair of pliers. Oh sure I could have instead talked about the female opening needing a hard squeeze from a good dike...
62Jeff is offline
Old 05-28-2008, 01:21 AM
buns
CF Senior Member
buns's Avatar
Shirley you are speaking of Dykes pliers???
buns is offline
Old 05-28-2008, 01:33 AM
Mikey65
CF Senior Member
New switch and new harness.. I will try getting a dike to squeeze it.
Mikey65 is offline
Old 05-28-2008, 07:03 AM
62Jeff
62Jeff's Avatar
But of course, and don't call me Shirley
62Jeff is offline
Old 05-28-2008, 09:46 AM
DZVette
CF Senior Member
DZVette's Avatar
Be gentle with that squeeze. That female part crushes easily.
DZ
DZVette is offline
Old 05-28-2008, 10:50 AM
5thvet
CF Senior Member
5thvet's Avatar
DZ
I put in new switches and harness last fall and had the same problem. Like DZ says be gentle with the crimp and the male will snap in . Ask me how I know!!
5thvet is offline
Old 05-28-2008, 06:03 PM
65vettish
CF Senior Member
65vettish's Avatar
Don't mean to hijack this thread but I'm at the same point as mikeyandem1 in the total replacement of wiring in my '65. My car has a dual master cylinder w/ proportioning valve. A previous owner spliced the wire running from the proportioning valve pressure switch into the tan wire for the emergency brake warning light. I assume he did this to create a warning light in the case of a change in brake fluid pressure at the valve. He left the bullet shaped connector on the end of the wire but it wasn't connected to the emergency brake. Here's my question: on my new harness, would you recommend doing the same thing? If so, are there any problems w/ connecting both the proportioning valve pressure switch and e-brake switch on the same tan wire from the new harness?
65vettish is offline
Old 05-29-2008, 12:14 PM
JohnZ
CF Senior Member
Received 1,123 Likes on 729 Posts
Originally Posted by 65vettish View Post
on my new harness, would you recommend doing the same thing? If so, are there any problems w/ connecting both the proportioning valve pressure switch and e-brake switch on the same tan wire from the new harness?[/I]
No problem - that's the way the factory circuit worked on the 67's - either the parking brake or the differential pressure switch would ground the circuit for the "Brake" warning light in the cluster.
BTW, that's not a proportioning valve - it's just a distribution block for the differential pressure switch - it has no valving function at all.
JohnZ is offline
Old 05-29-2008, 11:23 PM
65vettish
CF Senior Member
65vettish's Avatar
Thanks John! I really appreciate your input.
Tim
Old 05-30-2008, 09:38 PM
uvettcha
CF Senior Member
uvettcha's Avatar
Tim
I think its safe to say we all like Johns input........Hi.........tnx John
uvettcha is offline
Old 05-02-2016, 04:09 PM
urthegman
Junior Member
urthegman's Avatar
Default Thanks
DZ
I just wanted to say THANKS!!! I had a tan wire just dangling and with the help of your photo's the parking brake warning light and headlight on light now illuminate!!!!
urthegman is offline
Quick Reply: 1965 Courtesy and Parking Brake Switch
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
