Flickering headlight- bulb or wiring?
Last night while returning home from a car club get together, I noticed the left side headlight "flickering" on low beam. When I used hi-beam, the flickering stopped. Wiring all looks ok - does this sound like a bad headlight? Car is a 57. Thanks for any help.
John
John
Location: Park City to SoCal - according to the map it's all down hill. No bad days in Indian Wells, California
If it was a bad ground it wouuld make no difference - high or low beam.
I'd check the bulb. On low beam smack it a little and see if it flickers - might be a sign that the filament is about to go south.
If it stays on and does not flicker, you might also check for the wires being corroded etc.
Best of luck
Best of luck
Best of luck
Best of luck
Headlight switch. Replace it.
Best of luck
Best of luck
The same thing happend to my 60. I put in a new headlight switch and that fixed the problem. The old switch also generated more heat than a new one.
Im going to go with the bulb is going bad, I remember the prongs on the bulbs come loose after years or from guys yanking the plugs off. Try the bulb first, connector, switch, ground.
Update - I found that when car is not running, all seems well. When idling, flickering starts, then stops (again on low beam only). Increasing rpms didn't seem to make any difference. I checked connections, and now I wonder if this has something to do with the charging system? I am reading 17 volts at idle at generator, about 15 volts at battery (lights off); reading at gen. drops to about 14v with lights on. Any ideas?
Swap the bulbs from left to right and see if the problem stays on the left or travels with the bulb.
and keep us updated
and keep us updated
Now I am confused! Replaced the headlamp, rechecked connections at switch and light, same issue. No flicker when engine off, flickers when engine is running. I am wondering now if my voltage regulator is sticking? Why just the one light, on low beam, and not the other, or no problem on high beam??? I have checked and rechecked the wiring and connectors.
I had a similiar problem tonight. On the way home from a local cruise, my high beams started to flicker so bad that I actually think they went out a few times. Flicker was minimal at idle.I have replaced the headlight switch, 4 bulbs, alternator and voltage regulator within the last two years. I don't drive at night that often, but I still want to have dependable lighting.
