When to replace tires
I think I would be looking for new rubber pretty soon. Some people don't think these tires are dangerous, but with the amount of money these cars are worth, it would be silly to push your luck.
In other words, tires in Alaska, stored or on a vehicle kept mostly in a garage will last much longer than tires in southern Arizona, especially if the vehicle sits outside or in a hot garage.
Examples: I had 4 (almost) new BF Goodrich Comp TA tires stored in garage above the ceiling in Chicago area (they saw max temperatures during summer) for about 8 years, and were trashed due to dry rot cracking. At the same time, I had 2 used (and a couple years older) versions of the same tire in the basement, that looked like I had just put them there.
Tires on my boat trailer (always stored outside, but low mileage) needed replacement every 10 years due to cracking on sidewalls (I assume due to ozone and UV exposure.
Tires on my 87 Vette (also BF Goodrich Comp TA) purchased in 1993 had the be replaced last year only because the tread rubber had changed and had become much harder, and was a liability from a traction standpoint (including dry weather). Tread depth was still acceptable, and sidewalls looked great, and I certainly got my use out of them (about 65K miles).
In other words, you can change them at a prescribed year interval (probably wasteful in my view), or you can watch for the signs that the tires have reached "end of useful life".
Plasticman
The Goodrich Radial T/As on my '65 were twenty-five years old, but still looked brand new when I replaced them last Spring. They never went far from town, the car was garaged all of the time and stored in Illinois every winter.
However, when it came time to do a cross-country trip (Route 66 tour with Sting Ray Registry), I just didn't trust them anymore. Who knew what was going on inside after 25 years?
Harry
The date code indicated 2 of the tires were 3899, or built on the 38th week of 1999, & the other 2 were 4400, or the 44th week of 2000.
They look almost new with even the little nubs still on them and they show little signs of wear.
BUT...(This is the BIG BUT)
They're probably OK, and I haven't had any problems with them to date, but I just don't feel comfortable with 8-9 year old tires, especially not knowing their storage history etc, and with driving on hot summer asphalt.
So, I recently ordered a new set of Diamondback Firestone Indy 500's, which should be here shortly, mainly just for GP'S and...
Safety first, then all the other stuff.
I don't believe there is any industry concensus as to when a tire is deemed too old to be safe and no manufacturer to my knowledge has put that recommendation in writing. I do know there is some research going on.
I believe Ford is the only auto manufacturer to recommend 6 years as the limit but they are not in the tire business.
I am in agreement with Plasticman's theory on tires. I've probably had more tires a year or two old suddenly deflate as I have those that were past ten years old.
PS. When is the last time you heard of a Michelin passenger tire blowing out? When is the last time you heard of a bias ply tire doing likewise? I'm curious to what the answers might be.
http://www.consumeraffairs.com/tires/michelin.html
- Pat
This ten year limit tells me the average tire will last longer than 10 years. If discount tire is willing to accept the liability of mounting a 10 year old tire, I would say that a 15 year old tire IN GOOD CONDITION is relatively safe.
I think common sense needs to prevail here - if the tire shows no signs of cracking or dry rot or bulges/indents and it is 10 years old, I wouldn't replace it. Now -- that being said if I pulled a set of 20 year old tires out of storage and they looked great - I don't know that I'd put them on the car.
Brian
Tire shops know how to mount tires. They know how to inflate, balance and install tires. So where's the liability? It's in the drumroll you hear about tires that are X number of years old that are unsafe. No proof. Just mouthpieces jawboning that older tires are unsafe and the Lawyers will prove in court that old tires are unsafe. The jury award will not be based on facts, just on how the case is presented. So some of you guys that are buying $2-$400 ea. tires for your sporty little car will someday be forced to replace them whether they need if or not. The snowball is already rolling downhill.
[QUOTE=Allcoupedup;
I think common sense needs to prevail here - if the tire shows no signs of cracking or dry rot or bulges/indents and it is 10 years old, I wouldn't replace it.Brian[/QUOTE]
If you noticed, it didn't have ANY examples of old tires giving out. Something fishy here.
- Pat
- Pat
