1957 283 pistons
Received 1,843 Likes
All the fuel injected 283's including the '57 with solid lifters and also including those very few '61 hydraulic cammed 275 hp FI engines used the domed pistons which are very similar to the factory domed 327/350 pistons. They had two valve reliefs which meant there was a left and right bank piston
All the rest of the 283's got flat top pistons with four valve reliefs and the pistons were interchangable from right to left bank because of these two features.
This a link to a set on E-Bay that shows a good picture on the piston top. It saves me a trip to the garage as I have a NOS set waiting to go in a motor.
http://cgi.ebay.com/ebaymotors/Parts...=p4506.c0.m245
Jim
Jim
Verle
The 57 283 HP Corvette and Car had domed pistons. I have two engines with 57-60 type pistons. 61 had a fuller dome similar to the 62-65 FI dome. Come by tomorrow at 11 with a camera and take pictures of NOS 61 and used 57s. Free Goldies lunch.
Regards
Regards
Jim
Jim
Regards
Lunch is good anytime
anyone have a set of pistons I could use in a '57 fuely motor? kinda wanted originals if I could get them. My motor will have to go + .030"
is another catch.
is another catch.
The ebay picture shows a piston similar to the 61 FI piston. However I am curious as to whether it is GM. GM pistons generally didnt have the extreme indention in the center of the piston and the dome appears to contain more CCs than original. This is a observation and I might looking at them wrong. ie they might be GM.
Regards
Regards
Jim
61, 315 piston
This was pulled form a 61, 315 in 1968.
cast # is 3768469.
raised portion is flat, photo may look like a bulge or convex.
cast # is 3768469.
Received 1,856 Likes
NOTE: I have been told that the 61 FI piston dome will not clear a 57 997 head without modifying the head.
Ok, I went to John's shop and took pictures of some pistons.
57,61 and 65 (midyear HP) Fuel Injection
Notice the difference between the 57 and 61 dome shapes.
The 61 dome will not work with earlier heads because of combustion chamber difference, they will hit the head.
The 65 is similar to the 61 with a difference in the valve relief shapes and the 65 is a four inch bore.
57 FI still in the block
http://i35.tinypic.com/2ikcfma.jpg
61 FI
http://i36.tinypic.com/2crt1rk.jpg
65 FI
http://i37.tinypic.com/2py5m2q.jpg
61 FI
65 FI
Verle, thanks for posting the pictures. The 61FI pistons will clear the heads of the 57 283HPand 57 pass power pack heads. The #s etc on the 61 piston were put there by the people at JE when they built .070 over pistons for my 57 SCCA racer. I wanted to save the block that ran 57 Bridgehampton. The motor put a smile on Dick Guldstrands face when he ran it past redline last year at Meadowdale.
Regards
Regards
61 info
John,
No serial # on my bros in law 's car. I believe it was April-ish as some of the parts I have show April dates. So it must be at least in the 7,000s.
He had a knock in #1 or #3 and when we took the piston out it was cracked on either side of the pin but all in one piece. Replaced and ran well until he bent a rod and broke the block about 3 years later.
Joe
Joe
Verle
Verle,
Is that 65 a service piston?
Thanks,
Joe
Thanks,
Joe
differences in the 327 piston
Two pistons: one is a 327 replacement piston I purchased in the mid 70s. It matches exactly the pistons in a 1969 cast date CE 327 block.
The new piston is part# 3871208, cast# 3866954. Looks to be the same as the 65 photo Verle posted.
The other is in a March 64, 870 replacement block. Looks as if it was re-ringed with # stamped on the piston tops. Have not had any of those pistons out to look for the cast #. Assuming it is GM manufacture.
May be aftermarket of early 70s vintage?
Wondering about the differences between the two. Valve reliefs and presence of notchs???? Explained away if the pistons in the 870 block are aftermarket.
Optical illusion is really throwing my perspective off.
