C1 Steering gear lubricant
Received 2,126 Likes
Do a search on "gear lube". When the page comes up look for a post from DZAuto dated 4/22/07 it has good details for you to follow. Dennis
Exactly right - anything else WILL leak out. Look at the pictures on the bottom of this thread...http://forums.corvetteforum.com/show...teering&page=2
You will see the special fitting I made to pump grease into the steering box and the pan showing the old thin grease pumped out. You will see the 1/2 cup or so of thin grease in the pan before the new thicker grease began pumping out..
My steering box was nearly EMPTY from seepage over the years. You should make sure you have the right grease in the box as soon as possible.
I recommend GM chassis lube #12377985 for the manual steering box. It is the current part number for the lube originally specified/recommended by Chevrolet. The original stuff has been discontinued. Comes in a 14 oz tube. Costs about $6 a tube.
Any good chassis lube will probably work as well.
To fill the box without taking it apart, I used a special fitting sold by Paragon Reproductions. Part number #8581 . Cost approx $18. Works well. Others may also sell this fitting. LATER EDIT: I went back and rechecked the Paragon Catalogs, and the #8581 fitting is for year 1963 and up. For C1 cars you must make one yourself as described/shown by FDREANO in his post.
My 1967 (fairly dry) steering box took about 4 oz of lube to fill. I jacked up the front of the car during the filling step, and worked the wheels from left to right a few times to help distribute the lube and remove any air. You remove two of the three bolts on the top of the steering box: one to install this fitting (fill bolt) and another to vent. Leave the third bolt tight to prevent disturbing the box preload adjusting screw plate.
Larry
Larry
Larry
Larry
Here's another TOOL for getting grease in steering box. Just drill 1/8 hole thru bolt and add fitting. Then replace one of the steering box bolts. and grease away
George
George
Received 3,766 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Use a good grade of chassis lube.
Somewhere in the 1957 time frame, there was a GM service bulletin which instructed to use chassis lube instead of gear oil.
SOMEONE HERE has a copy of that service bulletin and it has been posted before.
I've asked multiple times for that service letter to be posted again and so far, it hasn't been posted. So, whoever has that service bulletin, would you PLEEEEEEEEEEEASE post it again!
We filled my steering box with grease that I purchased from the local Chevy parts dept.
We removed the plug on the box and pumped the grease in through a grease needle, we also had the front jacked up so we could turn the wheels left & right.
I made a hybrid lube consisting of high pressure grease and 140 weight gear lube mixed it so it was a bit more fluid than grease to avoid channeling...No leaks yet, it was still pretty thick.
Received 1,856 Likes
I'm guilty - I can't find the scan, and the original is in an old issue of "Vette Vues", under "Factory Facts", but I don't know which issue, and I have hundreds of them; not gonna dig through them now. Paraphrasing, the letter told the dealers to suck out the old gear oil and replace with chassis lube on Corvettes where customers complained about steering gear leaks; the letter attributed the leakage to the close proximity of the steering gear to the hot exhaust manifold.
I could care less about the quality of the letter's reproduceability so long as it is legible (I just want to print out a hard copy and add it to the library).
I also have Vette Vues from 1974-------------------boxed away in the attic and I don't even have a clue where the boxes are!!! But if you should run across it sometime, will you post it again?
I've been away from this forum a while because of a new project, a '54 Hudson Hornet. Excellent forum, you think some of the guys on this form are ancient....... Anyway, I use STP and I think it is superior to grease because it "sticks" to the gears and more viscous.
