Needs some advice....I soaked the threaded parts my rusted car jack in some knocker loose for a week or more...started out fine, worked back and forth, sprayed it often to keep it lubed with oil...then it happened...
el strippo...
the "nut" on the jack stripped so now i need to find out if i can replace the nut..
Does anyone know if its replacable.
If not
I guess it will be for show only. cause thats all they are used for anyway..
jack
Reason: added some more info
