Headlights Flicker
Headlights Flicker
The headlights on my 63 flicker a little, but only at idle or low rpm. Over the last three years I have replaced most of the parts. I've replaced dash switch, dimmer switch, alternator and headlight bulbs. The wiring appears to be OK. I do have a new headlight harness and bucket harness(s), but haven't installed them yet. All connections seem to be fine. The lights seem to work fine until I come to a stop.
Wayne is exactly right! The fact that it only flickers at idle, pretty much eliminates all other components. No real need to look at anything else!
Put a solid state regulator on it, and never have to file or adjust the regulator points again.
Regards, John McGraw
If the flicker is the headlight switch thermal circuit breaker kicking in then you have a whole different ball game...many folks have had to add relays for individual headlights to take the load off of the dash switch - plenty of threads here on that topic....
I replaced the voltage regulator that is located on the passenger side of the engine compartment, about 8 or 9 inches behind the horn. Can't remember the brand. I probably bought it at Advance Auto.
The electronic type is just that, the points are replaced by integrated circuits. Similar to the built-in regulators in late model alternators, although it could be in a metal housing similar to your old regulator. You'd only know it was electronic in that case by pulling the cover to look. Yep, you can switch to an electronic type, but someone else will have to chime in with a source.
If it makes a differance, although the car is a 63, the engine is a 69 350. If I switched to the more modern style voltage regulator, would I have to make any other modifications?
With any regulator you buy, you may have to drill a mounting hole in the body, for the capacitor to mount. On my 65, that capacitor is on the top of the regulator as seen here.
Do you have a good ground on the voltage regulator?
I have had other cars (Pontiacs) with the flickering lights and getting a good ground to the regulator did make a difference.
I installed a solid state regulator on my '64 Corvette (AutoZone VR-715). Charges just fine and lights are bright and steady.
