The news is bad
The news is bad
Figure I would start a new thread and make the current situation easier to follow
I pulled the valve cover after I could not find anything wrong in the exhaust and that is when things became a little more transparent.
For sure the #2 intake solid lifter is collapsed so I am going to pull the intake manifold and pan tonight to try and get a handle on the extent of the damage.
Hard to believe that with my now tuned old 850 DP on last night in place of my problem plagued 950 QFT that my car ran better than it ever had, even with a lifter already starting to fail
I guess that banging sound that I heard was the start of the lifter failing ........ oh well things can always be worse
Ever hear of Sulivan's law?....... simply stated it says that Murphy was an optimist
Maybe it will not turn out to be a total failure and all those little needle bearings will be in place and accounted for...... that would be some good news about now
I will update this later tonight
Thanks for all the replies and advice on the other thread
Doug
Doug
Cartoon Character
Man , what a drag.. That is what happened to mine too and when the cam gets de-lobed you have to hit the machine shop because you cannot get the metal out, no way. What a shame for you, sorry..
St. Jude Donor '05, '09, '15
Doug
Doug
The lifter on the right lost it's needle bearings.
Here's the cam.
The instructions that came with my Comp Cams retro rollers said to clean off the lube they were shipped with and dip in some other stuff, prior to assembly, to my recollection.
I would get a can of GM EOS and dip the roller part in that that prior to install, which is what I did.
You want good, high pressure, sticky lube on those rollers at first fire up.
Doug
Doug
The lifter was very difficult to get out and that was enough to tell that the situation was pretty bad.
Anyway the solid roller lifter has disintegrated so the cam is definitely wiped.
On the second build with this motor I had good spring pressure but not IMO excessive...... 260 on the seat with new springs and titanium retainers however I only had Comp Cams super pro lifters and that is what failed.
Lots of garbage in the oil so the whole motor has to come out. I just got the bloody car back on the road in January...... if I thought I would be happy with my 427 in it I would stick that back in there.
Maybe I should do that anyway but if I do then I will probably get rid of the car.
Doug
Doug
So, in your opinion, did the hard runs with your rebuilder:
1) Make matters worse
2) Didn't change a thing
I was wondering about the wisdom of that (although I might have done the same thing)....I've been in the "dammit - break if you're gonna break mode" before.
Had I not taken that ride there might not be roller needles all through my motor but in hindsight the only thing that I could have done to check for a "soon to happen catastrophic failure" that I did not do would have been to have drained and strained the oil....... and had I done that I am not sure that anything would have shown amiss before the roller disintegrated.
I went to bed that night quite confident that my problem was in the exhaust itself being as I had just checked the compression as well as just had the valve covers off two weeks ago for valve adjustment and every thing was fine.
However thinking back to when I just did the second build from the detonation of the first build and noted the very poor valve train movement from weak springs, I should have had the rollers rebuilt but I did not because there were only about 1500 miles on them. So if I did make a critical call in error I believe that is when I did rather than take it for a ride that I hope to be able repeat in the not to distant future as far as fun and making horsepower goes.
Doug
if your lifter bores are worn out, that will cause a roller to ride crooked on the lobe and cause a catastrophe. too much play will wipe a flat tappet because it causes the lifter not to "spin" and the lobe rides in the same spot and eventually wipes. lifter bores are overlooked so many times and are a most critical issue, this is especially true on a used or so called "seasoned" block.......
Doug
Edit: Because I had shaft rockers I went without a rev kit.
Doug
Doug
You drive the puppy on the street???? I would check some of the springs and see if any broke or are getting weak.
that is a cast roller cam not a hardened one so that could have caused the problem.
Doug - Sorry to hear about the damage. I was hoping you would find it was something minor.
Dan
Dan
AZ Doug asked
What would a rev kit have done for you in this case?
Muncieman said
This appears to be a full on roller cam, not a street roller. 260 pounds of seat pressure, must be over 600 open or more.
Doug
that is NOT a steel billet roller cam in the picture as it a cheaper cast iron roller cam that are not made for high spring pressures. a rev kit will prevent the roller from "skipping" on the lobe as it will keep the roller in the lifter in contact with the can lobe at all time.
It is good to be able to share both the good and the bad with others...... another plus here at CF section for C1&2 owners.
Doug
