T3 lookalike halogen headlights??
Did I read here sometime ago that someone makes a halogen headlight repalcementthat looks like a T3 headlight? Or did I dream that?
Thanks,
Doug
Thanks,
Doug
Got lows and highs at Nappa or VIP
Jack
Yes you actually can see at night at 100 mph
Jack
The original are fine for judging but at speed at night , they just don't see far enough ahead. Modern lights are much safer. That is of course if you can get your headlight motors to work. I don't know how many times I have had to spin that little wheel on the motor to drive at night.
Jack
Jack
When I replaced my dash wiring harness recently, the only issue I saw with the old one was that the 12v wire to the dimmer switch had been hot at the connection. Not sure if that was due to the current draw, or a weak connection. And, on these old cars, the entire current for the headlamps passes through the headlamp switch and the dimmer switch, unlike the recent models. That's assuming you're using the original wiring and haven't installed relays for the headlamps.
New harness and dimmer switch
That's why I'm running them, much brighter. One thing I haven't checked though is the amperage draw of the halogen vs the original headlamps.
No relays
The amp gauge seems to be happy even with lights on. I wish my oil pressure problem was as easy to solve.
Jack,
I saw these a while back on eBay, "modern / correct T3 bulbs", item #s: 110358025927 for 2-bulb sets, and 110360279299 for 4-bulb sets. I have no idea how good they are, just passing along the info.
These are the one the vendors sell. I believe they are brighter than original, but still more yelowish and not the the bright white/blue that a halogen will give. I upgraded my low beams to a modern lamp and put halogens on the high beams. Cost me like $22. My 3 good original T3's are on the shelf. Interestingly the remaining failed one was not an original T3.
I have looked at the ebay ad before and was thinking of pulling the trigger but was hoping to know if anyone had used. The ad http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem= states the following:
60 61 62 63 64 65 66 67 Chevelle Corvette Impala, Firebird, GTO, 442 - Guide T-3 Headlight Bulb Set.
Brand New - Beautiful OEM / Modern / Correct T-3 Headlight Bulbs:
Brand new reproduction sets
Produced using original factory blueprints
Correct! Having the original T-3 and GUIDE insignia
Improved for better brightness and longer life
Officially Licensed
Made by an OEM manufacturer in the U.S.A.
Available for many GM makes/models - see below
Sold in complete sets only (2 or 4 bulb sets)
Great care was taken to improve the photometrics and candlepower of these bulbs in order to meet the current Federal Highway Safety Standards, without compromising the original lens prescription.
Our 1960-67 bulbs will fit, and be exactly correct for all 1960-1967 GM vehicles with the 4 headlight bulb system using 5-3/4" bulbs.
Officially Licensed
Cartoon Character
Doug
A lot of guys at the pavillions are using the repro lights and they look good but can be told apart from the originals according to my fanatic originality friend Bob. Too bad this post is about a year too late. I took the T3 lights out of my car and replaced them with Halogens so I could use my car at night and gave the old lights away to someone who wanted them .. I will be removing the crappy sealed beam halogens and replacing them with a set of Hella lights with seperate bulbs soon as they really work well. It is a little tiresome driving down the road like Diogenes for sure...If you go to the Pavillions tomorrow there is a Pontiac, Buick and Oldsmobile show over there that is pretty cool. My friend Rich has a perfect 67 GTO convertible, blue with a white interior and he has repro T3's if you want to see them..
Ebay is the place to get them..
Officially Licensed
Officially Licensed
thanks - glad you like them.
I run these t3 repro lamps in all my cars.
They are brighter then original, and you know they are going to keep working.
Used to run originals only - but they would always fail at the worst time.
There is a very small "dot" mark on the 4 lamp sets - the two bulb sets do not have that marking.
They look as close to originals as you can get.
And even without the "dot" mark - the judges would still be able to tell, cause the color of the light is whiter -the old ones gave off a yellow hue.
I installed Halogen replacement lights in my Coupe several years ago. They definitely make a difference at night. However if you drive several hours with the lights on (especially high beams) your stock wiring WILL get very hot along with the headlight switch (it will get almost to hot to touch). I found it to be the same with my original wiring and new wiring after I did my body-off project. This winter I installed relays in both headlight circuits and the heat problem is solved. Another benefit is full voltage at the headlights.
Roy
Roy
Roy
Roy
I already have new repop T3's (Paragon, perhaps 2-3 years ago) which are OK, epecially with the relay circuits added.
Just looking for something brighter, that looks original, or as original as possible, if available; if not available, then I will simply do without the original headlight look.
I made a relay harness set that installs under the front panel and connects into the factory wring harness with no cutting or splicing, the relay harness can be removed and the stock headlamp harness plugged into the stock main wiring harness if so desired, in about 10 minutes.
A 10 gauge power wire feeds the relays direct from the battery/alternator.
Thanks,
Doug
Out of curiousity, what is wrong with the Hella lights and what/when are they supposed to do to make them work well?
Thanks,
Doug
Thanks,
Doug
You have a little more info on your relay set, where it plugs in, wiring schematic, which relays you used, etc.???
It simply plugs into the existing wiring harness, you unplug teh existing headlight pigtails from the connects are install this right there, relay activation comes from the main harness vis teh headligth switch, the relay sends power to the headlights.
I bought the relays and sockets online, someone here suggested a vendor. Std Bosch 15 or 20 amp SPST 5 pin relay.
You need one relay for the low beams and one relay for the highbeams.
I did also add an extra 12 gauge ground wire that connects to the frame near the radiator as part the new harness.
It isn't too hard to figure out a schematic, look at the relay info and make sure you connect to the right pins, and make sure you use different colored wire!
I used black for ground, green to connect to the green HB wires, and something else to connect to the tan LB wires, as I didn't have tan wire.
10 ga red was the main power supply wire to both relays. The ground wire, of courrse needs a node where the existing ground wires and relay coil grounds all connect.
Doug
Roy
Ron: If you decide to install relays, you can get the kits with complete instructions at Mad Electrical. They have a writeup about full power to the headlights here. I did the same before and after test on my car with the same results.
Roy
Roy
