Oil Line Mystery
Oil Line Mystery
I am restoring a 64 corvette with a 327 300 HP with Power Glide. I did not take my car apart but I am putting it back together. I have a mysterious hole in my block just above the casting for the oil filter which is 1/2 in in diameter and not threaded. I can see the oil filter canister bolt inside the block. What is this hole for and how does one close it?
Received 1,856 Likes
That's the outboard end of the main oil gallery - that hole should have a steel cup plug in it; don't recall the size offhand. See photo below.
Like John I don't recall the size either
but it's the same as the 3 gallery cup plugs on the front of the block.
When you put it in, use a sealant. I had a pretty good leak when I installed one dry. Used red loctite on the second attempt and it is bone dry 500 miles later.
