OT-tie rod pullers
OT-tie rod pullers
I've been looking at a couple 5pc front end service kits. KD tools KD41690, and OTC 6295. Consists of tie rod/ball joint pullers. If I figured out how to post a pic, I would. Just curious how well they work, taking into consideration how tight the stud(s) might be. Hate to bang away with pickle forks, with painted frame/suspension.
Skids:
I removed a fair amount of tie-rod ends and ball joints in my day, and never used a puller or a pickle fork.
We simply loosened the castle nut and replaced it with a standard nut or an extra deep nut (hardware stores sell these) to cover the threads, and then used a heavy deadblow hammer on the nutted stud. Worked every time for me.....although a few required a BIGGER hammer. If we knew we were going to reuse the joint we used the extradeep nut for max thread protection.
I never used a pickle fork, but was told that they can tear the joint rubber boot. Maybe if you aren't careful. Or not an issue if replacing the joint.
However, the pullers are not a bad idea, and will probably do the job more gently/efficiently.
Larry
Larry
Thanks Larry. I've done it that way also,BFH, but sometimes it's too tight of an area to swing the hammer, so was thinking that's where the pullers would come in handy.
on the tie rod end on the spindle, simply hold a dead blow hammer on one side against the spindle and smack the other side with another hammer ....works with just one hit!!.....
I just pulled the tie rod ends from the center link, the center link from the idler and pittman arms using the cheapie Taiwan pullers sold by NAPA. They worked fine. No damage to anything.
Rich
Rich
