pulled Hood Release Handle off - best repair?
my hood release handle pulled off, I see a ribbed shaft (not threaded) and wondered if anyone else has had this happen and the best repair? I am thinking of drilling and putting a set screw in the handle .. ??
I pulled mine off on the 61 a few months ago. I drilled and tapped the (bottom) of the handle shaft. Used a small allen wrench set screw and it works fine. Not visible unless you, put head under the dash and look up.
Joe
Joe
Mine came off about a year ago, due to a stress crack along the length of the shaft.
As a quick fix (I needed to open the hood!), I used super glue to repair the crack, and while it was drying I pressed it back onto the cable shaft and secured it with a tiny hose clamp around the circumference.
Worked like a charm, and you can't see the hose clamp unless you're looking for it.
I (gasp!) may just leave it that way.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
I used double set screws, but make sure you dimple the shaft with the drill tip so the set screws hold good. Obviously a common problem, and I thought I was so smart.........!
When I repaired mine, I opted for the method that was used on the originals, I believe. Took two pieces of flat stock steel, drilled the proper size hole between the two pieces while they were clamped together, then used the two pieces around the old handle to swage the handle back onto the rod. The rod has some upsets in it to prevent the handle from coming off. It's worked fine for several years, they just work loose over the years from all the times pulling and tugging on them to open the hood.
That said, if I have to do the one on the second car, I think I'll opt for the epoxy method. If you get a good epoxy bedding and completely fill all the gaps you eliminate any potential for movement between the rod and handle, and have full bearing between the two. I've never liked the idea of a set screw or bolt myself, I'm sure it'll work for a while, and possibly a long while, but it gives you a point loading on the handle rather than the full bearing you get with a swaged on handle or with the epoxy method.
Just my thoughts, don't go to flaming me because I'm not for the set screws. I know you guys are using them successfully, but not my deal.
Related question, what's the best way to lubricate the entire cable? Graphite, oil, white lube, silicone.....???
St. Jude Donor '07
or, carefully spray WD40 on the outside while it is in place and wipe off the excess as you go.... work the cable every once in a while to distribute the lube.
Bill
it's a wirewound cable, so it could removed and soak the whole assembly in oil. but if you can pull the inner cable all the way out, then i think white grease would be less messy.
Bill
Bill
