Using Nyloc Nuts instead of Nut and Lock Washer?
I am inquiring to find out the pro's and cons of using nyloc nuts instead of a nut an lock washer. Is there any area on the car where a nyloc should not be used, other than the exhaoust?
Nyloc's are common today and widely used instead of the nut and lock washer. Is there a life expectancy of the nylon used in the nyloc nut. Nyloc nuts are much easier to use and more forgiving on components.
I am not building a NCRS car, but have seen NCCC cars with nyloc's used .
Bob
Bob
St. Jude Donor '07
i see no problem with using nylocs, and use them with flat washers instead of lock washers. the only problem i can foresee is that repeated removal/reinstallation of the nut will degrade the nylon portion and after a few uses (and i can't quantify a 'few') it would be best to use a new nut.
Bill
Bill
Pros:
Won't vibrate off even if loosened up
Easier to use in tight places where it may be hard to keep a lock washer in place while getting the nut on.
Cons:
They don't like heat
harder to install or remove in tight places as it takes torque to turn the nut the entire time is is being threaded on or off, vs a simple spin until tightening or after loosening. Though not that big of a deal on a proper length bolt.
Doug
Cons:
Doug
Lock washers are for farm equipment
Once torqued past about 5 lbs the "lock washer" contributes nothing, its the clamp load produced by torquing to 80% of the fastener yield value that keeps the fastener tight. The best use for a lock washer is for visually being able to check if the fastener is tightened at all. Usually for some sort of high volume manufacturing process or on a farm. Always use self locking nuts (nylock), if heat is an issue there are deformed thread types. If you were obsessive compulsive, use them only once, otherwise two to three times max.
Ed Roth's Outlaw was disqualified from the Oakland Roadster show back around '59 because he had Nylocs in the front suspension/steering. Techs said it was a no-no. He kept building cars but I don't believe he entered one in competition again.
If it had been accepted, Barris' Ala Kart might not have won two Grand Nationals in a row.
Consider prevailing torque nuts (John S 1961 menitoned them too). They are crimped so the threads are no longer round. Fairly common are ones with a dimple on every other flat from the crimping process.
Great in vibration applications (we used them at VW for mounting engine accessories).
No issues with heat. probably more resistance to backing off than Nylocks..
Harry
Harry
Most Nylocls that you find in a hardware store are Grade 2 which are not very good for strength. I have a Speciality Fastener Store near me that sells hardware for performance and race cars that sell Grade 8 Nylock nuts. If you can find them, Grade 8 are are much better quality and a lot stronger. I even use Nylock nuts on the rear spring to trailing arm tie bolts. It makes it a cinch to adjust rear ride hight. The NCRS amy not like it but My 65 is a driver.
Go for it!!!
Chris, CWPASADENA
Go for it!!!
Chris, CWPASADENA
Go for it!!!
Chris, CWPASADENA
Go for it!!!
Chris, CWPASADENA
Go for it!!!
Chris, CWPASADENA
Go for it!!!
Chris, CWPASADENA
Chris, CWPASADENA
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
Jim
Chris CWPASADENA
That's the story and I SNAPPED an ARP bolt right in 1/2 and Jim you're right you only make that mistake once because it really gets your attention.
