Where to buy L79 cam?
Amazing how hard it is to find an L79 cam on the web! I'm interested in buying a new L79 cam that is made to original factory specs (if such a thing exists). Anyone have a supplier/part # for this?
Thanks-
Thanks-
L79 cam
Try Crower Cams, GM performance parts. Don't forget to put new lifters in with whatever cam you buy and either use an oil additive (ZDDP Plus) or run Rotella D, 15-40W. You will definitely need the ZInc. Otherwise, significant problems will occur,
Received 1,856 Likes
Simple. Federal-Mogul/Speed-Pro #CS-179R (cam only) or #KC-179R (cam and lifter kit); any auto parts store can order it for you. Used to be available from GM as a cam/lifter kit under P/N 12364050 (made by Crane). Use stock Chevy springs (P/N 3911068) or F-M #VS-677 (same thing). You do NOT need (or want) "hot-rod" valve springs.
among many other grinders, you might try elgin engine parts.....just google them.......
