Bending pushrods and breaking rocker arms!!
Please check the valve guide clearance. We had a car with aftermarket alum. heads. The owner was using a lead additive in the fuel. It affected the bronze valve guides and the valves would seize in the guides. It was tricky to find because sometimes the car would have a miss when first started that went away as the valves loosened in the guides. Other times it would just break rockers and bend pushrods.
TK
TK
make sure you do not have any lobes going off of the cam as this will cause this problem because if it is a exhaust lobe the exhaust pressure in the cylinder that can't get out will cause push rods to go thru the rocker arms
[Thanks. I am definitely going to check the lobes. That is something I have suspected as well. My buddy is bringing over a dial indicator for me to check them with. Jim
TK
TK
You guys will jump all over me for not mentioning this, I don't want to feel like an idiot, but I have had slight detonation a couple of times. I know John Z says I can run this thing on pump gas with today's fuel (and I am sure he is right), but whenever I haven't used higher octane VP in with the regular premium, it has happened. It was real slight and I got off of the gas immediately. I know it is in my timing curve and I need to address it, but I hope this hasn't caused the pushrod/rockerarm issue? I have had the heads off in the past and saw no internal damage or anything. Just thought maybe I should throw that in the mix. JIm
It doesn't seem possible for detonation to cause any problems with the valve train. After all, when detonation takes place, both valves are closed.
You might also want to check your pushrod guide plates. I had to replace mine when I bought my engine from a supplier in California (he installed guides for 7/16 pushrods and used 3/8 pushrods...jeez.). I dropped two exhaust valves (retainer just popped off) before I figured out that the pushrods were rubbing the base of the guide fork, eventually causing the exhaust fork to break off the rest of the guide plate. A new set of correctly made guide plates solved that problem for good.
If you've had the heads off and have satisfied yourself that there is no piston to valve interference, the most likely cause of your problem is coil bind in the valve springs.
The detonation is not causing your rocker problem. I would pull the heads and have a trusted shop check the spring installed height,check for coil bind at your cams lift, retainer to seal clearance and valve stem to guide clearance. TK
2021 C1 of the Year Finalist - Modified
You don't need to take the heads off to check coil bind ! Just roll the engine over so a valve is full lift (verify with dial ind) and slip a feelers guage in between the spring coils. l'm guessing this is your problem but keep us informed.
Well guys, I have pretty much ruled out the camshaft. We checked the lift etc., today and no cam lobes worn. However, my friend brought up a good point. The rockers I have been using are GM number 10112680 and they a "O" (or maybe it is a square) cast into them. I think the originals were hardened and had a "H" (for "hardened"). This might just be the problem. I probably also need to use hardened pushrods...weren't they originally hardened due to being a HP engine? Thanks, Jim
Seem to maybe be getting this possibly figure out. I checked and found that the original hardened rockers are still available through GM Parts Direct.
See below:
Current GM Part Number 12368082
DESCRIPTION: ARM KIT
These 1.7 ratio hardened steel arms have elongated slots to provide extra clearance for high-lift (.600") camshafts. This rocker assembly includes arms P/N 3959182 plus the ball and nut, for use on all 396-502 big-block heads with adjustable rockers. Technical Notes: These long slot rocker arms are stamped "H".
See below:
#33
Received 6,527 Likes
C2 of Year Finalist (track prepared) 2019
ARP is quite clear on this subject: Don't use self locking nuts with their rocker studs. Use Poly-loks instead.
I wouldn't be so bold as to say this is what's causing the problems you've had, but it's something that isn't quite right. I'd change it.
Jim
#34
You've got an "interesting" problem. I just went back to the beginning to read the full history and one thing jumped out at me: the use of ARP rocker studs and factory, self locking nuts.
Jim
Jim
#35
Long slot rockers
Been dealing with a weird issue for two summers now. Have a 67 427/435. Running an offbrand solid lift cam...Elgin...spec card attached. My machine shop thought it was a good cam. I think it is junk and is the root of my problems. I keep finding on either the #3 cylinder, or the #4 cylinder, that the pushrod will push through the rocker on the exhaust and bend the pushrod on the intake valve of the same cylinder. I am absolutely sure that the valves were adjusted properly per the specs. (many times over I should say) Originally, I thought they may be too tight, but what I discovered was that the studs were worn and the nuts were backing off. When they would back off, I thought it was getting a pounding action and causing the pushrods to push through the rocker arms. Therefore, I put all new hardened ARP studs and new factory nuts. It would run fine for a week or so, and then missing etc. Pull the valve covers and same ole issue! This latest time as you can see in the photo, the end actually broke off of the pushrod (thank goodness it was laying in top of the inside of the head and didn't get into the engine!!) and then pushed through the rocker arm. I even pulled the heads and checked the piston/valve clearance. No issue there. I have had several solid lift engines and have never had this problem. Had a stroker with a solid roller cam that would take over 7500 rpms and never and issue like this? Am I nuts? My opinion is that I have a junk cam and that is the root of my problem, but what do you guys think? Thanks, Jim
If the rockers binds on the stud, to much lift for a stock rocker, that will break parts. If the cam lift pushes the retainer into the top of the valve guide that will break parts, if the spring coil binds that will break parts.
The seals will get hammered by the retainer beating on it and oil control will become an issue. To fix a retainer to guide issue you need to remove the heads and machine the top of the guides.
All this stuff should have been done at the time of engine assembly so if a shop did all the work they need to fix the problem.
Guide to retainer clearence, coil bind and rocker geometry and push rod length all should have been checked, part of the deal.
#36
In the picture you posted of the right bank of the engine with the valve cover off, it appears that the discoloration of the #4 exhaust and the #6 intake rockers indicates that they were running much hotter than the others. This suggests an oiling problem. Have you run the engine with the valve cover off and watched for adequate oiling through those pushrods? Perhaps there's a blockage in the lifter oil gallery?
Also, pull those lifters and put them foot-to-foot to make sure that they are still convex. If they're flat or concave, the added stress on the cam lobes has done damage.
#37
I'm not sure how oil starvation could bend pushrods (unless the valve stem siezed up in the guide) but I could see how the additional friction and heat could lead to damaged rocker arms. Perhaps you could run the engine with the valve covers off to verify proper oiling. I use small glad sandwich bags on each rocker arm and spring to prevent oil from being squirted everywhere.
#38
The H on the rocker stands for high lift, not hardened. These rockers have a longer slot. They are what you should be running. If oiling was a problem, the rocker ball or rocker should be badly worn. Factory hi perf rocker ***** had oiling grooves in them. Do yours? Do your valve covers have the drip rails in them? The factory used them to direct the oil splashed from the pushrod onto the pivot ball. I still think problem is rocker or valve guide related.
If the self locking rocker nuts are not backing off, they are not an issue.
I would run the GM "H" rockers and GM 3/8" pushrods, which should cure any oiling issues.
#39
I don't know, but after looking closer at the pics of the rocker arm, it looks as blue as a gun barrel in the ball area and the pushrod pocket area. Since it would be such a simple variable to check I would definitely make sure I was getting proper oiling.
#40
Hi guys. To answer some of the questions you raise. part of the reason you don't see a lot of oil is b/c I haven't started the car up in several months. I see what you say about the discoloration but I think that is the poor lighting in my garage as well as my cheap camera. In person, they all look normal colored. The lifters all look good and no concaved ones. The nuts are not backing off at all. The valve covers have the drippers. I have watched oil come through all the pushrods and the car generally has really good oil pressure. One guy suggested that I check to see if I could fit a bent paperclip up under a rocker next to the stud when the valve was fully open. I could not fit the clip in the slot underneath which seems to indicate that maybe the rocker is right up against the stud causing binding?? I have ordered new GM "H" rockers where the slots are bigger and new 3/8 GM pushrods. I also think that maybe my valve adjustment was a little lax on some of the valves. If this is not it, I think it must be a spring issue, or the retainers are hitting guides, or maybe coil bind. When I look at the springs compressed when the valve is fully open there is plenty of room (at least on the outside one that I can actually see). Not sure what is going on with the inners. I was hoping that this might be a simple matter of incorrect rockers...As to the *****, some of mine had grooves, others were smooth. The one that just tanked had grooves. My new GM "H" ones come with the new nuts and grooved ***** (man that sounds funny . Keep any thoughts coming! I will certainly let you guys know what we come up with. I keep trying your suggestions. Thanks, Jim
