knuckle bolt Grade??
C2 knuckle bolt Grade??- Urgent need answer tonight
I finally got my lower knuckle bolt and nut monunting kit from Dr rebuild for my c2. The new bolts have 3 slashes. As I am doing a frame off I am storing all the original hardware. I noticed the original bolts had 5 slashes with a w in the center. These are critical bolts as they hold the front knuckles and caliper brackets. Now maybe I changed those bolts many years ago to a higher grade and they are not the originals...Does anyone know if the 3 slashes is ok?? I do know the higher grade bolts can be brittle. Just want to make sure.
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
3 lines-Grade 5
5 lines-Grade 8
Personally, I'd prefer Grade 8 bolts for this application.
Tom Parsons
5 lines-Grade 8
Tom Parsons
Not sure
I know grade 8 is stronger but it could be more brittle on shear. I know I am being a granny on this. Just called paragon and they sell grade 8 for this application. Would feel most comfortable going with what they originally came with.
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
For critical applications, like holding on suspension or brake parts, the only bolt head logo I use reads "ARP".
Jim
Need more input!!
I want to put my hubs on tonight-already have the dr rebuild 3 slash bolts on and torqued. Can anyone tell me what origonals are-I have my originals ready to go if they are the originals.
2015 C2 of Year Finalist
I just did this yesterday on my 67. The bolts I took out were grade 8 with 5 lines and "M" headmark (probably the "W" yours have). I believe these to be correct, but had some damaged threads from being loose on the drivers side (yikes!).
I ordered all my replacement fasteners from Paragon based on experience (they have the highest winning percentage of sending quality and and correctness in my book). These fasteners are Grade 8 (6 lines) and marked "LE". They install with crimp nuts on the inside. Torque to 60-80 ft-lbs.
